    Hello guys how can i stream a video from my pc to a computer outside lan ?
    Is the LAN firewalled ? Nat'd ? Content filtered ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    its behind a router .
    Is this a home router ?
    The more details you give, the more likely you are to get an answer. If we have to drag every detail out of you then we are likely to just give up.
    If it is a home router then you might look at VLC, and also port forwarding, as a starting point
    the pc that i want to stream is on home router. The client pc is on home router as well but on different location. firewall is disabgle o both pc's streaming and client
  6. Always Watching guns1inger's Avatar
    You will have to set up port forwarding on your router for the port you will stream on. See portforward.com for instructions on many different routers. Start streaming with VLC on that port. The other PC attaches to your IP address and port (nnn.nnn.nnn.nnnpp). Note : this is the IP address of the router as provided by the ISP, not the IP address of the PC that is actually streaming.
    You should not have to turn any firewalls off to do this.
    the ip address i will ahve to use is the ip addres from e.g. what is my ip .com ?
  1. 5.1 over LAN
    By prizi in forum Computer
    Last Post: 10th Jun 2007, 15:06
  2. Replies: 4
    Last Post: 23rd Jan 2007, 17:45
  3. Replies: 0
    Last Post: 17th Jun 2005, 20:55
  4. Stream video to television via LAN
    By davedeal in forum Newbie / General discussions
    Last Post: 12th Dec 2004, 10:28
  5. How can i stream live video on my lan
    By Closing in forum Capturing
    Last Post: 24th Nov 2002, 18:54
About   Advertise   Forum   RSS Feeds   Statistics   Tools
