I've got BD Rebuilder working on my main computer,but I can't get it to work on my other two computers. It starts to encode but I quickly get x264 encoder failed error. I've installed ffdshow,haali splitter,and Avisynth. ???????????????
Results 1 to 15 of 15
Thread: BD Rebiulder x264 encoder error
Have you tried to reinstall them? I got the x264 encode once or twice and I believe I fixed it by reinstalling the "extras".
Pull! Bang! Darn!
I re-installed the programs and I'm still getting the error.
Try a previous version of BD Rebuilder perhapsOriginally Posted by wulf109
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
Tried all the early versions back as far as beta time out permitted.
What are the titles that you are trying on the other two computers? Have you ever gotten successfull backups on those computers? What are the computers specs?
Just noticed a new version on x264 encoder has just been posted. Trying downloading that and dropping it in bdrb.
Dropped in latest x264 but same problem,encoder failure at about 3%. My backup computers are not hooked up to the internet,could that be the problem?
Are you overclocking @ all on the cpu or memory, or running tighter timings on the memory?Originally Posted by wulf109
ocgw
I'm overclocking all three computer:
i7 2.66 to 3.6
e8400 3.0 to 4.0
AMD X4-620 2.6 to 3.3
Memory is overclocked on i7 and E8400,not the AMD x4-620,5-5-5-15 timing on the i7 and e8400,default on the AMD (1066)
BDrebulder runs fine on my i7 and it has both the CPU and memory overclocked.
BD Rebuilder "pegs" all your cpu cores, it is the only program I run that makes me reduce my overclock when it is hotOriginally Posted by wulf109
This could really be an OC issue
Stability when overclocking is an issue which may be solved w/ a little extra cpuv, unless temps becomes a factor
The other concern is temps it self, are you monitoring your temps?
Sometimes a little extra NBv helps because of the memory controller setting on the cpu die, also adding v to the SB or HTT bus may help
Reduce your overclock first to stock and then run BD Rebuilder again and see if it fails, if not then slowly work up a stable overclock for BD Rebuilder and note the settings
ocgw
It is an overclock problem. I dropped my AMD 620 to it's default speed of 2.6 and it encodes without issue. I have moved upto 3.2Ghz and it seems stable at that speed. I dropped the E8400 to 3.6 and it also seems stable,but it is painfully slow. You really shouldn't use anything but a quad to encode with BD Rebuilder.
Glad to hear you solved the problem.
Tell me about itOriginally Posted by wulf109
lol
glad you got it sorted out
ocgw
FFdShow x264 Encoder
By prijatelj.v in forum Video ConversionReplies: 2Last Post: 26th Mar 2012, 07:16 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
upadating x264 encoder
By jamesj84 in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2012, 02:23 -
BD Rebiulder Pretty Smart
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 27th Jan 2010, 16:07 -
x264 encoder from x264.nl or videolan.org?
By StephanP in forum Video ConversionReplies: 1Last Post: 4th Feb 2009, 14:38
