I am looking for a DVD/VCR RECORDER WITH A USB PORT that will play my videos via Flash Drive through my HD TV -- I am interested in Recommendations -- It is hard to tell if this feature is available by info on the net or even by asking a sales rep-
I did manage to find out that the following DVD VCR RECORDER combo units have this feature: SONY rdrvx560 ($170) and the LG rc 897t ( $220 )
Are there any other concerns about the above units that I should consider? Any Net reviews ?
Does anyone know of any others or what is your opinion of the above--
Thanks,,,,Ralph
Dont buy combo units like that,best to have a separate dvdrecorder and vcr in case you have to use a tbc between the vcr and dvdrecorder for copy guarded tapes you own,cant copy those types of tapes with a combo unit plus they are built cheap.
Ben Johnson-I didnt take any stereos!
Hi Johns0,
Thanks you for your quick reply--
My purpose for this type of unit is mainly to copy DVR ( NON-COPYRIGHT) TV programs that I wish to save and to make singing or speaking recordings-- The VCR part for converting ( non- copyright ) tapes to DVD is essentially just an extra since the price differential is not much --
I am interested in your comment that combo units are made CHEAP-- Is it the VCR part that is made cheap or the whole thing ?
Are you saying that DVD RECORDERS are made better ? If so , why and do you know of any that you can recommend?
Still looking for the combo unit info as as above.
I sincerely appreciate your info--
Thanks,,,,,Ralph
From johns0
_________________
Have you researched the Western Digital media player (Model: WDAVN00BN) for your flash drive files?
Prices should be no more than $100.00.
Hello LJB,
Thanks for your help, but I would still need the DVD VCR RECORDER COMBO , for everything else so it would not be worth it-- regular 4gb or 8gb flash drives to plug into a USB port are basically all I need --
Thanks,,,,Ralph
FROM LJB
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / HDTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
dvd player with USB port (with NFTS support)?
By themaster1 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 10th Nov 2009, 19:33 -
playing DVD images via USB port
By cbrylla in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2009, 13:08 -
DVD Players with USB 2.0 port
By nicoarad in forum DVD & Blu-ray PlayersReplies: 12Last Post: 28th Oct 2008, 21:06 -
DVD player with USB port
By Scooby Doo 12345 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 08:35
