I have a Panasonic BD-60 Blu-Ray player so it can only play AVCHD I guess. I authored a AVCHD disc using TSmuxer but on my Blu-Ray player, the picture is vertically stretched. The picture looks like it is supposed to have the black bars on the top and bottom, but it doesn't. Is there a way to correct this (using either tsmuxer or multiavchd)? Thanks!
What was the source? 16x9 Camcorder? Anamorphic DVD?Originally Posted by hiimbored
What is the TV monitor? HDMI connected 1080p 16x9, or...?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Source was a Blu-Ray, and the file is a 1080p mkv file. The TV monitor is HDMI connected to 1080p 16x9.
Use uncropmkv to re-encode the video and add black bars to the top and bottom so that way you will have a compliant video. Then run through tsmuxer or multiAVCHD and your video will be in the correct aspect ratio.
In uncropmkv, do I have to change anything besides the "Resize" option? I switched it from 1920x800 to 1920x1080, does that sound right? I'm just trying to add black bars to the top and bottom so I can watch it on my 16:9 TV.
UncropMKV should work it all out when you load the video. The only change you should have to make is to select an appropriate encoding quality. For a 720p video with a running time of around 95 minutes it takes around 10 hours to encode using 2-pass VHQ on a 6600 Quad Core using 3 cores.
If your computer specs are correct in your profile, you could be looking at 24 hours or more for a result.
Try using 2pass fast encoding with uncropmkv,takes me 2 hours to re-encode a 100 minute mkv 1920x800 to 1920x1080,the bitrate will be high enough as long as the clip isnt a fast paced action thriller.Using 2p vhq to me is too long a time unless its very important footage.
Ben Johnson-I didnt take any stereos!
Aspect Ratio with AVCHD
By EliG in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 19th Oct 2007, 02:50 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 10:21 -
To change Aspect Ratio to 16:9
By nakul610 in forum Video ConversionReplies: 2Last Post: 19th Dec 2006, 15:55 -
change from 4:4 to 19: aspect ratio
By taterg in forum Video ConversionReplies: 3Last Post: 12th Sep 2003, 14:35 -
How do I change the aspect ratio
By pcostanza in forum Authoring (DVD)Replies: 1Last Post: 12th May 2003, 13:15
