VideoHelp.com Forum
  1. Hello Ladies stiltman's Avatar
    I'm wondering if someone can take a look at this. It's a query generated by Handbrake.
    Just wondering if I can tweak it to some thing better? Normally I use Xvid in an avi wrapper, but I'm switching over to H.264 in a MKV. I don't have much experience with H.264. It will be played on a 42" plasma via a WDTV player. I forgot to add, I'm looking for best results, aka least blocking and artifacts, as long as it's less than the original mpeg2 size.
    -i "C:\DVD Rip\TEST_DVD\VIDEO_TS" -t 1 -c 1-29 -o "D:\Movies\TEST_DVD no cropping.mkv" -f mkv --crop 0:0:0:0 -p -e x264 -q 0.65 -a 1 -E ac3 -B 160 -R 0 -6 dpl2 -D 1 --markers="C:\Temp\VIDEO_TS-1-chapters.csv" -x ref=3:mixed-refs=1:merange=24:no-dct-decimate=1 -C 4 -v
    Here's a screenshot of the advanced settings
    Originally Posted by jagabo
  2. Member usta's Avatar
    I would add/change (all aimed to increase quality with the expense of time needed to encode):
    B-Frames: 6
    Motion Estimation Method: Uneven Multi-Hexagon
    Subpixel Motion Estimation: 9
    8x8 DCT: check
    Trellis: 1
    No Fast P-Skip: Check
  3. Hello Ladies stiltman's Avatar
    Why add B-Frames?
    Yeah, I'm not worried about encode time. I usually add 3 or 4 to the que and then let it go
    Would it be better to crop the non-movie areas or leave it as is? I noticed if I crop, it'll use a little less bitrate, and resulting file is a little smaller.
  4. Member usta's Avatar
    B-frames can use both previous and forward frames for data reference. This will achieve better data compression (smaller file size).
    If I use crop (especially with autocrop), then my videos do not end up with the "standard" resolution, say 720x400. Then again, the encoder doesn't have to process the "useless" black borders.
  1. muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
    By codemaster in forum Video Conversion
    Last Post: 20th Sep 2011, 20:50
  2. Replies: 4
    Last Post: 27th Apr 2010, 11:41
  3. Handbreak MKV h.264 settings help
    By darkdream4 in forum DVD Ripping
    Last Post: 1st Jan 2010, 06:06
  4. DV AVI -> H 264 (bitrate and other settings)
    By xprezons in forum DVD Ripping
    Last Post: 31st Aug 2009, 02:13
  5. Replies: 4
    Last Post: 18th Jul 2007, 09:25
