Results 1 to 15 of 15
  1. Member Wanderlustus's Avatar
    Sorry folks, I know this has been covered ad-nauseum, but for the life of me I can't remember how to do it. Can someone point in the direction of the appropriate thread?
    Cheers,
    Wanderlustus
  2. Member hech54's Avatar
    ImgBurn
    EZ Picker Mode
    Write Files/Folders To A Disc
    Choose the FOLDER
    Burn
  3. Member Wanderlustus's Avatar
    Originally Posted by hech54
    ImgBurn
    EZ Picker Mode
    Choose the FOLDER
    Burn
    Many thanks, Hech.
    Oops. I don't see that option in the pull-downs.
    Cheers,
    Wanderlustus
    Wanderlustus,
    I don't think you need specific instructions for this task. Just use a program such as ImgBurn to burn it. Start-up ImgBurn, Select Write Files to Folder, select the VIDEO_TS folder, burn.
    -The Mang
  5. Member Wanderlustus's Avatar
    Originally Posted by louv68
    Wanderlustus,
    Sorry mate, but I don't see an option to Write files to folder.
    Cheers,
    Wanderlustus
  6. Banned
    Wanderlustus,
    of course he meant write files/folders to a disc which you would know what he meant if you'd see it:
    Kinda hard to miss it, ya know
    Either you have older version, or you disabled the "ez-picker" startup option... both your own "fault"
    HTH
  7. Member Wanderlustus's Avatar
    Oh yeah, I have an older version. Oops. 2.3.2.0
    Grabbing the update now. Thanks.
    And yeah, it's obviously my own "fault," though I wasn't blaming anyone for anything. Except maybe myself for being so forgetful.
    Cheers,
    Wanderlustus
  8. Member Wanderlustus's Avatar
    And with the newer version everything is just grand. Burning as I write. Thanks for the help, and thanks Dere for the "humbling" experience.
    Cheers,
    Wanderlustus
  9. Member Wanderlustus's Avatar
    Man, that verifying sectors takes a wee bit o' time.
    Cheers,
    Wanderlustus
  10. Banned
    YW
    Once a while do:
    Help -> Check for update
    Yeah, I know. It's not only ImgBurn, it's the same with all of them. It's been a while already since the "burning" technologies outperformed disc reading technology.
    If I make few copies, I only verify the "archival" copy. That saves lot of time.
  11. Member Wanderlustus's Avatar
    It's on auto check.
    Cheers,
    Wanderlustus
  12. Member hech54's Avatar
    Turn off the Verify thing after this burn. You can trust ImgBurn to get it right the first time.
    You can turn it off permanently in the options.
  13. Member Wanderlustus's Avatar
    Thanks again, folks. I was wondering about leaving the verify on, Hech. Should be safe to turn it off in mid verify, shouldn't it? It's been ages since I used the prog', but I'm fairly sure I had it turned off before.
    Eh, bugger it. 6 mins to go, then I'll shut it off.
    Damn, I love this forum.
    Cheers,
    Wanderlustus
    If you are using good media and ImgBurn, then auto verify may not be necessary, but I still use it anyway. Before I found out that not all DVD media is reliable, I had a few burns that apparently succeeded but failed verification. Since I don't often make multiple copies, I want to be certain my only one is accurate.
  15. Member Wanderlustus's Avatar
    Cheers all. Worked great. And thanks for the input, UQ.
    Cheers,
    Wanderlustus
  1. burning from ISO vs burning from VIDEO_TS folder
    By ibzomie in forum Newbie / General discussions
    Last Post: 23rd Jul 2006, 23:18
  2. Burning Video_TS from GUI_FOR_DVDAUTHOR
    By RKDYork in forum Authoring (DVD)
    Last Post: 23rd Nov 2005, 14:37
  3. burning VIDEO_TS from hd
    By viper786 in forum Newbie / General discussions
    Last Post: 25th Nov 2003, 08:40
  4. Burning a VIDEO_TS to DVD-R
    By teeswizard in forum Authoring (DVD)
    Last Post: 24th Jul 2003, 10:00
  5. VIDEO_TS burning
    By mightymo in forum Authoring (DVD)
    Last Post: 15th Jun 2003, 20:22
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
