I just purchase a copy of vobmpg pro.
But everytime I try to register it, it just close itself within 7 seconds.
The register process can never be finished.
How and when can I start using it??
I've never seen so lame copyright protection before.
Results 1 to 14 of 14
I will refund you. Drop me an email.
I had this same issue. I installed VOB2MPGPro to my Program Files directory instead of the defaul c:\VOB2MPGPro\ directory... I don't like installed programs on my root directory... the registration wouldn't complete. I uninstalled the application and reinstalled it accepting the default location and the regiestration completed just fine.
Wonder if it's possibly an issue with UAC, then. (Edit: Except the OP is on XP...
I had the same issue as well. The solution for me was the set compatibility mode for VOB2MPG to Windows XP SP2 and then I could register with no issues.Originally Posted by Ai HaibaraIntel Core i7 920
Windows 7 Pro
I am also having the exact same issue, the suggested fix to set compatibility mode for VOB2MPG.exe to Windows XP SP2 does not resolve the issue for me.
What should I do?
Drop me an email and well register it manually.
Yesterday I checked the availability of VOB2MPG 3.0 (free version) with my PC
(Windows XP Japanese ed), and after that I purchased a vobmpg pro.
But also in my case, it closes itself within 7 seconds.
I reinstalled it to the default directory, but same issue was occurred.
What should I do?
Can you take a look at this post in the forum:
http://forum.videohelp.com/threads/3...guage+settings
And see if your Language Settings are similar?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thank you, ChrissyBoy.
Owing to the thread you indicated, the problem was resolved although changing language setting is troublesome.
I think there are many user of VOB2MPG in Japan, especially for converting DVD for Toshiba Regza,
so I hope that this problem will be cleared in future revision.
It is something that has proved difficult to nail down but it is an known issue we are seeking a solution to it!
I'm having an issue getting through the firewall at work, I can't complete the reg process.. Any help would be great
Mark
Can you drop me an email and we will do it manually?
I had this same issue. and my Language Settings is "10002(MAC - Traditional Chinese Big5)",Help me please.
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
Unable To Register BOTH SVCD2DVD & VOB2MPG Pro
By noyou in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 1st May 2010, 21:23 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Registration won't finish (vob2mpg pro)
By kfealz in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2010, 07:13 -
VOB2MPG PRO Runs But Doesn't Process
By majones in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 23rd Dec 2009, 04:11
