    I used vob2mpg v3.0 many times before, last time i try i have this problem:
    The program not create a log file.....
    I try the version 2.5 with same problem, but this time was created a log:
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title:
    Version: 2.5.0.0
    Executable: H:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe
    Executable size: 460 KB
    Executable size in bytes: 471040
    Executable CreationTime: 1/1/2000 00:00:00
    Executable LastWriteTime: 1/1/2000 00:00:00
    Executable LastAccessTime: 1/1/2000 00:00:00
    ****************************** Drives *******************************
    **********************UNABLE TO GET SYSTEM INFO*******************
    ********************** Input Folder *******************
    18:49:56: Volume in drive Z is DVD_VR
    18:49:56: Volume Serial Number is 4DD7-862D
    18:49:56: Directory of Z:\
    18:49:56: 03/01/2006 22:12 <DIR> VIDEO_TS
    18:49:56: 03/01/2006 22:12 <DIR> VIDEO_RM
    18:49:56: 0 File(s) 0 bytes
    18:49:56: 2 Dir(s) 0 bytes free
    18:49:56: Z:\>
    ********************** Output Folder *******************
    18:49:56: Volume in drive P is LAU HD EXTERNO 1TB (1)
    18:49:56: Volume Serial Number is 1887-5BDD
    18:49:56: Directory of P:\124
    18:49:56: 09/10/2009 13:21 <DIR> .
    18:49:56: 09/10/2009 13:21 <DIR> ..
    18:49:56: 2 Dir(s) 227.992.981.504 bytes free
    18:49:56: P:\124>
    I already try change the source and destination, with no results
    Sry my english, and thx in advanced
  2. Member ChrissyBoy's Avatar
    Can you take a look at
    http://forum.videohelp.com/topic373834.html
    and see if you also have a WMI issue.
    thx for reply...
    yes, before i post here, i already try...
    anymore ideas?
  4. Member ChrissyBoy's Avatar
    Do you mean you have the same issue with WMI and System Info?
    yes, is the same problem with wmi, but that solution didnt work for me...
    anymore ideas?
  7. Member ChrissyBoy's Avatar
  1. VOB2MPG-Pro Finished processing 0 vobsets
    By jay782 in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Oct 2009, 02:10
  2. VOB2MPG 2.5 Finished processing 0 vobsets. Duration 00:00:00
    By d4d9d4 in forum SVCD2DVD & VOB2MPG
    Last Post: 24th Jul 2008, 17:31
  3. svcd2dvd RC9b CANNOT SHRINK FINISHED FILES
    By mark220478 in forum SVCD2DVD & VOB2MPG
    Last Post: 13th May 2005, 16:19
  4. Replies: 1
    Last Post: 13th Apr 2005, 22:49
  5. just finished burning in nero... with ati ... vcr files
    By ratz in forum Newbie / General discussions
    Last Post: 15th Oct 2002, 14:45
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
