I've used the software TSSplitter V1.2 to split some M2TS files by size
but it doesn't have the function to split the file by Chapters.
Is there an easy way to split by chapters?
Tony
Didi you ever find an answer for this? I also need the same thing.
Thanks!
No I did not but, If you change the files to MKV MKV merge can split by chapters.
This is an answer tothe question on the MakeMKV forum by Wasabi.
If you're a complete newbie to MKVMerge here's a simple step-by-step method:
1) Open the MKV in MKVMerge
2) Under the Chapter Editor menu item, choose Load, then choose the same MKV that you just opened - it will now take a few seconds to import the chapters.
3) Under the Global tab, check Enable Splitting and ...after timecodes.
4) Under the Chapter Editor tab, highlight Chapter 01 and select the long timecode from the start box below (you can skip the Chapter 00 that is all zeroes)
5) Click on the Global tab and paste this timecode into the ...after timecodes box, then add a comma
6) repeat 4 & 5 with each successive chapter
7) click Start Muxing
Hope this helps
Tony
Thanks Tony I will give it a try!
Hello Tony:
I just tried the MkMerge from the CLI, using the timecodes to do the splitting and everyhitng works except that I have some Audio Sync issues. Do you have any idea if there is a general way to fix this kind of issues?
Thanks!!
easiest method to convert movies with multiple m2ts files (seamless branch)
By zero7404 in forum Blu-ray RippingReplies: 3Last Post: 22nd Aug 2011, 08:10 -
Split *.m2ts to mkv
By Emil007 in forum Video ConversionReplies: 11Last Post: 18th May 2010, 10:18 -
easiest way to split audio and video
By ir0n_ma1den in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2009, 20:21 -
easiest way to slap my m2ts vids on a DVD?
By templedog in forum Video ConversionReplies: 2Last Post: 12th Nov 2008, 00:25 -
i need to split m2ts files for PS3
By domerdel in forum EditingReplies: 6Last Post: 11th Nov 2007, 01:36
