    I was wondering... If I want to connect my cable line to a HDD DVD recorder
    (Pioneer DVR-660h-k)which dosent have a built in atsc tuner, and then run it to my hdtv which dose have a built in atsc tuner, will I have any problems recording tv shows and viewing them on my tv... Thx
    ATSC won't work with cable. It's only for over-the-air reception. You need a QAM tuner for cable.
    Ok would i need a QAM tuner if I already have digital cable ?
    If you want to record directly from the cable coming out of the wall you need a QAM tuner. And note, most digital cable channels will be encrypted. You will only be able to record "clear QAM" channels. Usually that's only your local broadcast stations and a few others like a shopping channel and a local access channel.
    If you want to record the analog output (s-video, composite) from the cable box you don't need a QAM tuner. You won't find any DVD recorder or hard drive recorder that will record high def (HDMI or component) from the cable box. Hollywood has made damn sure of that.
  1. Can you connect a PC to a DVD HDD device?
    By ktmsprocket in forum DVD & Blu-ray Recorders
    Last Post: 26th May 2008, 21:25
  2. Replies: 2
    Last Post: 14th Dec 2007, 00:20
  3. Replies: 0
    Last Post: 23rd Oct 2007, 23:56
  4. Connect standard DVD player to HDTV with S Video cable?
    By rocketman in forum Newbie / General discussions
    Last Post: 13th Oct 2007, 02:33
  5. Connect DVD Recorder to PC to backup HDD.
    By Vanna in forum DVD & Blu-ray Recorders
    Last Post: 19th Dec 2006, 19:44
About   Advertise   Forum   RSS Feeds   Statistics   Tools
