Hello, I am hoping your knowledgeable people can help me find a cheap-to-reasonably priced Blu-Ray player that can also play high-def MKV files through USB, writable DVD, or whatever input device may be available (SD card, whatever). Support for AVI files isn't importaint since I have that covered with my MVIX. It doesn't hurt to have Netflix support, though I currently do not have that service so it isn't a must. I am trying to find something under $200, preferably around $150. Will I have any luck finding something like this?
Results 1 to 26 of 26
Highly doubtful in your price range. I have a BluRay player that has some MKV support, but I haven't tested this as that not what I use it for. My player cost over $300 US. I found some info that some manufacturers are either supporting MKV right now (LG) or will very soon if not now with a firmware update (Samsung) but I couldn't find anything for under $300 US that had it. Maybe others know more than me on this.
Just tried a short MKV file on my PS3 last night...No Go. To play a MKV thru a USB port you will need to find a player that accepts NTFS or Exfat. Either that or cut your MKVs into 4gb chunks.
I bought a WD media player for $99. It is not a disk player but it plays NTFS and will play MKV files.
Tony
This might do what you want for around your price range
http://www.engadgethd.com/2009/04/25...p-mkv-support/
http://www.google.com/products/catal...wAw#scoring=tp
I just clicked on the Engadget link and it says the player plays .MKVs but when you put the model number in JVCs homepage the product comes up but it doesn't say anything that the page on Engadget says. Nor does it say it on Amazon.com where they have it for sale. I would guess you would have to roll the dice and hope Engadget is on the money
LG BD390 can play mkv files.
Popcornhour C-200 is the ideal product for you... but i think that it will be "buyable"
only within 2-3 month because now they have production troubles and the firmware is definitely unripe
Thanks for the info, I will look into those!
http://resources.jvc.com/Resources/0...T2007-001B.pdf ...page 30Originally Posted by Bwizzy
MPEG4 file requirement
MPEG4 file compatibility with this player is limited as follows:
• Available resolution size: 1920 x1080 (W x H) pixels
• The file names of MPEG4 and subtitle are limited to 50 characters.
• MPEG4 file extensions: “.avi”, “.mpg”, “.mpeg”, “.mp4”, “.mkv”
• This unit does not support the DivX file.
• Playable MPEG4 subtitle: SubRip (.srt / .txt), SAMI (.smi), SubStation Alpha (.ssa/.txt), MicroDVD (.sub/.txt), SubViewer 2.0 (.sub/.txt), TMPlayer (.txt), DVD Subtitle System (.txt)
• Playable Codec format: “XVID”, “H.264/MPEG-4 AVC”
• Playable Audio format: “Dolby Digital”, “DTS”, “MP3”, “WMA”, “AAC”
• Sampling frequency: within 8 - 48 kHz (MP3), within 32 - 48 kHz (WMA)
• Bit rate: within 8 - 320 kbps (MP3), within 32 - 164 kbps (WMA)
• CD-R/RW, DVD±R/RW, BD-R/RE Format: ISO 9660+JOLIET, UDF and UDF Bridge format
• Maximum Files/Folder: Less than 650 (total number of files and folders)
• Not all the WMA Audio format is compatible with this unit.
• This player support H.264/MPEG-4 AVC profile Main, High at Level 4.1. For a file with higher level, the player will ask whether you want to play or not.
• Displaying subtitle file is not available for video files with “.mpg” and “.mpeg” extensions.
• HD movie files contained on the CD or USB 1.0/1.1 may not played properly. BD, DVD or USB 2.0 are recommended to play back HD movie files.
I'll let you know after you find me a new mazarati for the price of a carola.Originally Posted by l0ngview0
You might amuse yourself in the interim with the
asus o
popcorn c-200
wd hd tv -- version 2
accept nothing unless it can mount multiple simultaneous (lan) CIFS shares with authentication support, stream without downloading, open firmware or open api for community expansion, can receive a transcoded stream from another lan box for formats it cannot play direction, eSata for really local NAS, and definitely nothing that is first generationwebsearch: The Peoples Cube
You've got to ask to know. I remember back in 2002 the dirt cheep APEX DVD player was the first one I owned that played VCD and SVCD perfectly. My $200 one didn't do that.
Originally Posted by HalfAzPVR
^ direction == directlywebsearch: The Peoples Cube
The problem with Blu-Ray players that Play MKV is that they are limited to 4GB in size. That OK for HD TV shows but not movies.
So that limits you to:
1.) HTPC
2.) Media Streamer link Popcorn Hour
3. ) PS3. But you will need MKVtoVOB.For the love of God, use hub/core labels on your Recordable Discs!
The LG BD390 supports ntfs drives thru the usb port and plays mkv no problem.
reasonal price and with mkv?ok,there is a good recommendation to you
Samsung BD-P1600 Blu-ray Player w/BD Live, Netflix
not matter the price and the device ,all meet your needs,haha,dont miss the chance to get it.
http://www.dealstudio.com/searchdeal...662&ru=2860012
I've been looking around for a Blu-Ray player that had a USB and played DivX. I found 2 but they are UK models only and I'm in the US. After almost giving up, I found this one:
LG Network Blu-ray Disc Player BD390
* Player Type: Blu-ray Player
* Color: Black
* Disc Changer: 1-Disc
* Disc Playback Capability: Audio CD, CD-R, CD-RW, Blu-ray Disc, BD-R, BD-RE, DVD, DVD-R, DVD-RW, DVD+R, DVD+RW
* File Playback Formats: MPEG2, MPEG4 AVC, SMPTE VC1, AVCHD, DivX, DivX HD, MKV
* Video D/A Converter: 148Mhz / 12-bit
* Audio D/A Converter: 192KHz / 24-bit
* Decoder: Linear PCM, Dolby TrueHD, dts-HD, Dolby Digital Plus, Dolby Digital 2 ch Down Mix, Dolby Digital, dts
* Model #: BD390
As you see it also plays .mkv and HD as well. The USB is on the front. I've read a lot of good reviews on this model and it's also rated #3 on the most recent Comsumer Reports mag. Oppo was #1 and I forget #2. However, those didn't have the capabilities I wanted and cost more. This one right now is around 275.00. It appears that it had been on sale recently for 249.00 so I'm waiting to see if maybe it goes down again before I buy.
The LG390 almost seems to be that Perfect Player a lot of people have been waiting for - Network capable, NTFS support, MKV playback, BluRay player... Actually, if it combined these wonderful capabilities with the SD Freeview recording abilities of the LG 400 I'd be seriously considering binning my HTPC!
Ok, so I totally have no idea what SD Freeview is or what you mean by "binning my HTPC" Can you explain?SD Freeview recording abilities of the LG 400 I'd be seriously considering binning my HTPC!
I'm pretty new to this.
Thanks,
Breny
You can remux mkv to mpg and it will play on PS3 via USB stick or drive.
Regards,
Rob
Você somente perde qualidade e deixa de ser MKV. Hohohohohohohoho!Originally Posted by rhegedus
O Bluray player LG BD370 lê MKV - eu tenho um. A caixa-preta WD TV HD Player também roda MKV - eu tenho uma.
Dizem por aí, que, o LG BD390 também roda MKV - mas, este eu não tenho e não posso afirmar. Anybody else também diz que o Samsung 1500 suporta MKV com updating de firmware - mais ai, eu duvido.
Eu afirmo: LG BD 370 e WD HD TV Player supports MKV. Eu os possuo!
A porta USB do BD 370 não é compativel com NTFS - somente FAT32. Aí, não tem graça nenhuma!... O ponto alto do MKV é a sua superior qualidade. Se comprimir perde esta qualidade e, assim, é melhor ficar com o DVD mesmo. A bem da verdade quando agora eu assisto a um filme em DVD torço o nariz. Depois que conheci o MKV e similares se tornou difícil querer assistir a outros formatos inferiores de vídeo.LG BD 370 - WD TV HD Player
I just purchased the Insignia - Blu-ray Disc Player NS-BRDVD3 from Bestbuy for $129...it plays mkv on DVD5 and AVCHD burned on DVD5 will not play on DL DVD9. Plus it is a Netflix player as well...you will have to do the latest firmware for the NetFlix...but for $129 not a bad player...there is a good thread about this player over at the avsform.
No you don't!Originally Posted by phantom2010
It's a remux, not a transcode.
p.s. English, please
Regards,
Rob
loughary you may want to check the units specs. Some units like the Samsung will only play DVD-R I can't imagine it not playing DVD DL so try a DVD -R DL disc.
l0ngview0 I'd highly suggest simpy reconverting the Mkv's to AVCHD. If you are going to bother with burning the discs you might as well make them fully compatible with 99% of the Blu-ray players out there. Plenty of simple freeware programs on this site to do the transcoding & if the MKV is already a proper size i.e. 1920 x 1080 or 1280 x 720 then no re-encoding is necessary & a simple 5 minute mux in tsmuxer to compliant AVCHD is all that is required.
[quote="rhegedus"]
Fica difícil raciocinar em português é escrever em inglêsOriginally Posted by phantom2010
Melhor ler em inglês e escrever em português. Se eu for usar um translator perco tempo e perco a linha de raciocínio
São gramáticas muito diferentes. Já estive aí (States), e me dei muito bem!... Geralmente, eu conversava com quem queria me vender algo. Os caras (guys) entendiam tudo o que eu dizia. Hehehehehehehehe
Vamos internacionalizar o debate
Qual soft você usa para fazer este remux?
A conexão USB do PS3 suporta arquivos de vídeo maiores que 4 GB? Ou seja, suporta um device com formatação em NTFS?
Se não suporta!...
Um arquivo HD com tamanho menor, perde sim - muita - qualidade em relação ao Bluray que lhe deu origem. O 720p é inferior ao 1080p. Quanto menor a resolução (frame/data rate) ou o bitrate, menor a qualidade. Ninguém investe "uma nota preta" (to much bucks) para comprar um Bluray Player para assistir a filmes com qualidade proxima a DVD, ou mesmo inferior em cenas de maior movimento. Joga isto em uma tela de 40" ou maior, e vais ver somente pixelamento.LG BD 370 - WD TV HD Player
Tks for tsmuxer.Originally Posted by a1677c
I have downloaded some movies in .m2ts (extension). Burned it didn't plays in LG BD370. What must I do, for to do that, without quality loss? Please!...LG BD 370 - WD TV HD Player
Excuse!...
I understood now!... The language used here - officially - is English. I think that I'll be reading only what you write.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Blu-Ray player as strong as WDTV in MKV support on DVD
By mesowetodit in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Sep 2010, 02:03 -
Blu Ray to MKV with optioinal multi-language audio/subtitle support
By minerva.thegift in forum User guidesReplies: 7Last Post: 10th Sep 2010, 10:04 -
Best Blu Ray player w/ DivxHD, mkv and Xvid support?
By T.rex in forum DVD & Blu-ray PlayersReplies: 23Last Post: 20th Nov 2009, 11:23 -
Multimedia Player with Blu-ray/HD-DVD support
By Guiboche in forum Media Center PC / MediaCentersReplies: 7Last Post: 6th Oct 2007, 19:50
