VideoHelp.com Forum
  1. I've been fighting with several videos that play fine most of the time, but start to get choppy during high-motion sequences. Most notably, Earth (2007 Blu-Ray.) I'm running a dual-core Intel 2.53GHz cpu and an nVidia 9600 video card. For what's seemed like months, I've experimented with VLC versions, Zoom Player, MPC, etc. After exhausting searches, I finally found the solution. MPCHC (Media Player Classic Home Cinema) is the total fix for my problem. Even though MPC lets you send your output to the video card's GPU (using the EVR option for Vista/Windows 7), it was still choking my CPU at 40-70% playing 1080p content. After moving to MPCHC AND using the EVR option, my video not only plays perfectly smooth, but it dropped my CPU level down to around 5-10%, even during the high-motion sequences that bogged my PC down previously. As far as I'm concerned, there should only be one player to use for MKV for now....MPCHC! I hope this helps others that have encountered the same issues I have. For the longest I thought my processing power wasn't enough, but it was all in the right software and configuration. Best of luck!
    try splash and will drop your cpu to 2-3% maybe
    1.0.2 still doesnt support mkv subitles but 1.0.3 should support it
    Could you please let me know specifically what you configured in MPCHC? I am trying to mess around with settings I don't understand but I am not having any luck to remove the choppiness.
    I would appreciate it
    Thanks!
    Never mind, I had a hardware issue.
  5. Thanks man, this helped a lot!!
    MPCHC is now my default player for 1080p videos!
  1. choppy playback of 1080p content with mpc-hc and dvbviewer
    By codemaster in forum Software Playing
    Last Post: 4th Mar 2012, 16:43
  2. 1080p MKV playback using MPCHC
    By pb_cruisader in forum Newbie / General discussions
    Last Post: 29th Jan 2010, 12:57
  3. 1080P MKV playback issue
    By nekromantik in forum Software Playing
    Last Post: 14th Jan 2010, 16:40
  4. Replies: 1
    Last Post: 12th Apr 2009, 19:23
  5. Slow MKV 1080p Playback!
    By The_WRATH in forum Newbie / General discussions
    Last Post: 19th Aug 2008, 13:50
