I need to add "property of" to a video, the video would be a avi file. I would like the text to be there the length of the video. Suggestions?
Results 1 to 11 of 11
Thread: Adding text to video....
VirtualDub + logo filter
Is there a guide? I just wanted to add three words to the video.
A guide using VirtualDubMod's built in logo filter:
http://www.softwarehowtos.com/articl...244173137.html
This one uses VirtualDubMod and Donald Graft's Logo filter which has more features than the built in logo filter.
http://forum.videohelp.com/topic248307.html
A guide on youtube:
http://www.youtube.com/watch?v=XKPypXzpI7I
Donald Graft's Logo filter comes with complete instructions:
http://neuron2.net/logo/logo.html
If all you want to add is text then maybe you only need to add in a subtitle:
http://forum.videohelp.com/topic170420.html
I've had no luck with this project. There isn't a easy way to do this?
What program will create a bmp file that is just text?
Gimp
Paint.net
Photoshop
Pretty much any graphics program can do this
Even Windows' crappy Paint program.
I have the bmp file, when I try to save in virtualdub mod the file exceeds 8 gigs. The orginal flie is a 240mb vob. Suggestions?
Use compression
Video=>compression
all you need for the text effect is avisynth
http://avisynth.org/mediawiki/Subtitle
some examples at the bottomI love it when a plan comes together!
Ricardo Santos
adding text to video
By Doug K. in forum Newbie / General discussionsReplies: 3Last Post: 22nd Oct 2011, 16:45 -
Adding Text to FLV Video
By eaglei1982 in forum EditingReplies: 2Last Post: 12th Feb 2011, 09:16 -
adding text to a video
By Grunta in forum EditingReplies: 0Last Post: 6th Feb 2009, 21:09 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 15:03 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14
