VideoHelp.com Forum
Results 1 to 11 of 11
    i felt i had to write a new thread. since i had a bad experience . i wanted to hear from others . who maybe did the same .
    i burned 50 traxdata blu-rays . i think made by riteck .
    anyway . when i went to check them again to play some of them . i realized they were no good no more. the drive would not detect any disk anymore .
    the data was lost . integrity of the disc or the drive,
    this is my question . since i did not want to take any chance . i returned the drive lg and got a new one . but i am not sure if it is the problem.
    so here it is : is it possible for a drive to write superficially that the disc: blu-ray here would be okay and visible to the eye and turn bad and lost data integrity later on .
    could the drive do that.
    i had all those blu-rays checked with software and visually to make sure they were good at the time .
    could it be the fault of the drive and not the media . thanks
  2. Member hech54's Avatar
    You returned the wrong thing. Traxdata makes some terrible
    DVD media. I would blame TraxData over LG any day.
    I know you cannot "return" all of those blu-ray discs...but
    you are blaming the WRONG company if you ask me.
    did not get me right . i returned also the traxdata. remember, i am talking about the blu-rays . not dvds .
    and they were not cheap either .i am not blaming anbody. just did not know what to think . it was so bad . half of the 50 were bad after a couple of months or so .that was to unreal to me
  4. Member hech54's Avatar
    Traxdata makes JUNK DVD....so I would not expect their Blu-Ray stuff to be any better.....that is my point.
    thanks
  6. Member hech54's Avatar
    So let me get this straight angel40204?
    You buy complete GARBAGE blank media....then you go and post STUPID remarks
    in the burning software comments/rating section for ImgBurn?
    UN FREAKING BELIEVABLE.
    obviously , some read my comments very fast and forget some extra i wrote in. no, sony is not trash bd-r. and i the fact i could put more files size on my bd-r with imgburn , i found that disturbing .
    unfucking believable.
    as you say, i dont care about your reaction. i am not looking to make one. i gave my full experience and you should value it . as i had to do that before even anything was written about bd-r media or burners .
    the fact is sony bd-r was corrupted as well . as i checked it at the end .
    read my first post .
    also, why nero would not allow me more space than imgburn does . do not know. i just know the result .
    if just because you are a friend of the maker of this software , you reply to me with anger . stuff it . ic end up costing me some money.
    for traxdata , when i was using those, they were no info on bd-r . and thay cost as much as 5 euros in europe .
    now the price is down from a year ago.
    so don't get me for the media . if you go to check on site like i did , they still maintain traxdata as a reliable media right after sony and verbatim being the best on the next best bd-r with other brands. i was also suprised . that site was showing results form using those medias .
    anyway, i am staying away from imgburn for bd-r . i can't in all conscious recommend this software .
    the fact it did what it did with sony media and i had no problems with nero, as i also burned media grade bd-r without errors at all made me say that .
    also, allowing 200 mb more of movie could create an overburn which you would not know till you use other software .
    i found that out when i redid one old disk corrupted .with same files number
    hech54. read my post entirely in the imgburn section . moron.
    than , you can say something valuable , since you did not in this section that helps others
  9. Member hech54's Avatar
    Originally Posted by angel40204 View Post
    read my first post
    OK.....
    TraxData= GARBAGE(always have been garbage)
    Ritek= GARBAGE(now)
    ...so it MUST be the burning software??!!
    That's funny....
  10. Member hech54's Avatar
    Are you having a good time here angel40204? I see you have developed quite a fan club over at the comments section for ImgBurn.
    I FREAKIN LOVE IT!!!!
  11. Member Noahtuck's Avatar
    We have a new F$#*TARD of the year winner!
    LMAO!!!
    Originally a member since 2001, LONG LIVE TARAN's!!!
  1. Replies: 14
    Last Post: 4th Apr 2010, 20:40
  2. Hard drive failure/recover data
    By bhbuckeye in forum Computer
    Last Post: 12th Apr 2009, 21:50
  3. Nero failure burning "Audio & Data cd"
    By spiritgumm in forum Audio
    Last Post: 15th Oct 2008, 16:25
  4. LG ggw H20L...
    By BDR in forum DVD & Blu-ray Writers
    Last Post: 27th Feb 2008, 09:54
  5. Pioneer 420H - Can't Write Data Error
    By cie3 in forum DVD & Blu-ray Recorders
    Last Post: 23rd May 2007, 22:51
