Results 1 to 13 of 13
    Long time lurker and converter of DVD's no problem
    I have been converting Blu ray movies, transformers and iron man to mkv files using ripbot, tsmuxer etc.
    Both converted well and the quality is excellent, the issue is that the video stutters.
    I have a quad core AMD phenom II overclocked at 3.6ghz with 4Gb Ram and a ATI hd4350 video card running windows 7. ITs fast and has zero problems playing the original Bluray at all
    Im have tried using VLC player to play the MKV along with KMPlayer anf both stutter when playing both MKV's
    Is there something im doing wrong, i dont think so, so is there a player that can play the files properly?
    any help is much appreciated
    I should also say i have tried to use MakeMKV which does not encode the video at all and it also stutters so i dont think its a conversion issue
    Maybe this should be in the Blu-ray to AVI/MP4/MKV/WMV section?
    Can an admin please move it?
    Okey, moving you.
    Try also play using MPCHC.
    Have you tried play any other mkv hd? Does it stutter?
  5. Mod Neophyte Super Moderator redwudz's Avatar
    Have you tried MPC-HC? It's more optimized for HD playback. If it still stutters, you may have a problem with your video card drivers or hardware acceleration isn't working correctly with your card. In VLC, did you check 'Tools>Preferences>Video>Accelerated video output (Overlay)'?
    I have a ATI 3870 and it has no problems with MKV playback.
    And welcome to our forums.
    Thanks for the welcome guys and thanks for moving this thread baldrick.
    I have no problem playing MKV files of converted DVD's on my PC with VLC and yes the Accelerated video output (Overlay) is checked . This is the first time i have tried to play a HD file, however I was fairly confident that it was converted properly.
    Anyway i tried using MPCHC, already had it on my PC but never used it, and it seems to play ok, no stuttering!
    Ill test it more tomorrow as its now 2am here but it seems to be ok
    Thank you very much for the help!
    ok getting very frustrated now!
    Re-encoded Transformers last night and tried to play in all 3 players, VLC, KMPlayer and MPCHC. all 3 players the video stutters.
    I have also used MakeMKV so there is zero re encoding and it also stutters
    Anyone know whats going on?
    I'm starting to pull my hair out now!
    no idea whats wrong!
    Blu rays play fine with powerDVD!
    Well i have tried to mux the mkv i had to a M2TS file and try and play it with powerdvd as it played the original blu ray no problem but it had stuttering problems too!
    Im now trying to extract the raw 30Gb file as a M2TS file and play that with powerdvd to see if it stutters, we shall see.....
    ok so i tried XBMC and it plays both MKV's no problem no stuttering, hurrah!
    HOWEVER, XBMC does not go fullscreen on an external screen (PC to TV via HDMI)
    i want to cry!
    back to the drawing board, xbmc stutters!
    ARGH!
    ok reinstalling windows and only installing MPCHC plays all mkv's fine, so there must be a conflict between some software/drivers i had installed
    Are there any known issues with software/drivers when playing mkv's?
    I haven't heard of any drivers causing issues, but I'm suspect of some other codec packs. It sounds like you had several media players installed and I'm wondering if you had a conflict between a few different video codecs (just a guess, though.) I'm glad it's working now, but I have not seen that particular issue before so I don't know what else to tell you.
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 1st Dec 2011, 06:10
  2. Playing store purchased Blu-ray Movies - The Video and Audio stutters
    By orfajackson in forum Newbie / General discussions
    Last Post: 10th Oct 2009, 02:28
  3. My Conversion stutters slightly...
    By biged670 in forum Video Conversion
    Last Post: 29th Jun 2005, 16:53
  4. Replies: 2
    Last Post: 10th Dec 2002, 06:28
  5. Video fine, Audio stutters on low bitrate vcd's.
    By randallc in forum DVD & Blu-ray Players
    Last Post: 25th Oct 2001, 08:02
About   Advertise   Forum   RSS Feeds   Statistics   Tools
