VideoHelp.com Forum
Page 3 of 3
FirstFirst 1 2 3
Results 61 to 66 of 66
    Originally Posted by poisondeathray
    I edited my post above^. You have to make the stills longer in duration to match
    Don't use DelayAudio() unless you have overhanging ends on both sides of the audio,otherwise you can get silence gaps
    e.g. the audio is 40 seconds, but the the section you want is 30 seconds in the middle (5 sec ends on each side). Then you would use delayaudio to shift it insync
    I don't understand. It looks like you are showing me how to make my clip 30 seconds but I want it to be 20 seconds.
    Every which way I do it the intro plays fine alone but flubs the audio when the movie is appended.
    In my latest try the last word of the intro mp3 is being replaced by the first word.
    Could it be a problem with the movie file and not the intro - that is causing the intro to break at the connection?
    You said you wanted it 30 sec for the 3rd clip?
    Just change the values then for 20 seconds e.g.
    a = ImageSource("a.png", fps=25, end=100)
    b = ImageSource("b.png", fps=25, end=200)
    c = ImageSource("e.png", fps=25, end=499)
    a++b++c
    ConvertToYV12()
    vid=last
    aud=DirectShowSource("audio3dlong.mp3").SSRC(48000)
    AudioDub(vid,aud)
    Trim(0,499)
    Since all the other clips worked in appending, I suspect it's this 3rd clips fault, or how you prepared it. When you have overhangs, you experience the repeats exactly as you described when appending
    If you can't figure it out, just re-encode the whole thing
    I mentioned "30 seconds" meaning I had so much trouble trying to make the audio exactly 20 seconds I'd take 30 instead, run the avs and do a trim to get just the first 20 seconds (of avi).
    Maybe I can combine the avs scripts and see if that works better than the append.
    I just need to figure out how to combine
    a = ImageSource("a.png", fps=25, end=99)
    b = ImageSource("b.png", fps=25, end=149)
    c = ImageSource("e.png", fps=25, end=249)
    a++b++c
    ConvertToYV12()
    vid=last
    aud=DirectShowSource("audio3.mp3").SSRC(48000)
    AudioDub(vid,aud)
    with
    AVISource("Moviecut.avi")
    Trim(147484, 148922) ++ Trim(149978, 154715) ++ Trim(154834, 157708) ++ Trim(157816, 158014) ++ Trim(158157, 159866)
    a++b++c
    ConvertToYV12()
    vid=last
    AudioDub(vid,aud)
    firstvid=last
    secondvid=last
    firstvid++secondvid
    Make sure the first intro script works properly by itself, otherwise it wont work
    Mission Accomplished. It worked!
    Thanks!
    I'll be back to bump this later when I try the KenBurnsEffect on the final end credits.
    It's worth understanding why this works.
    Because the two videos are joined with the ++ operator (firstvid++secondvid), an AlignedSplice is performed, so that if the audio from firstvid is longer than the video part, it will be truncated to fit. If you had used the + operator instead (UnalignedSplice), the video and audio parts would be joined independently, making the second video out of sync.
    @poisondeathray: I think you were getting confused by the clips a, b and c. These are independent images to be shown for 4, 6 and 10 secs each to give a total of 20 secs, so end=99, 149 and 249 was correct all along.
  1. how to add intro video on multiavchd?
    By ps3z in forum Authoring (Blu-ray)
    Last Post: 29th Jan 2012, 13:43
  2. Completely Useless with this ...Add intro to already made DVD
    By stressbag in forum Newbie / General discussions
    Last Post: 5th Feb 2010, 06:02
  3. How to add short intro image to video?
    By Bytez in forum Newbie / General discussions
    Last Post: 2nd Mar 2008, 08:00
  4. What is the easiest method to add intro clip on DIVX ?
    By rob3rtz in forum Newbie / General discussions
    Last Post: 7th Oct 2007, 04:35
  5. Replies: 1
    Last Post: 1st Oct 2007, 11:29
