I have any video files in real format. played at traditional TV(via PC/output TV) be high resolution video. But if i played use LCD TV it will low resolution video. What's problem? What happen it's? How to repair it.
Tq.
Results 1 to 14 of 14
What outputs are you using from the computer to the TV? Composite (yellow RCA) or s-video? You will only ever get standard definition out of those. If you use VGA, component, DVI, or HDMI you can get high resolution. But if your source files are low resolution you won't get any better picture quality.
The image hasn't changed, however the resolution of the LCD is potentially up to 6 times that of a standard TV, so the image of tghe video has to be enlarged a lot to fit. Depending on the method of resizing being used, the quality will vary. If you are not resizing at the computer end, and just passing a low resolution image through to the TV to have it resize, the quality could be very poor.
I suspect that your source is not very high quality, and that your old TV hides a lot of the issues with it.
I don't know that source high or low resolution but i convert from DVD source, i use guide in this forum (title: How to make VCD karaoke from DVD karaoke). After that i convert result MPEG fle to file real media with Real Producer with startdard setting.
I used S-Video output Computer to TV. But ever testing used HDMI output too. The result is same poor at LCD TV.
I tried resize convert with Real Prodecer but the result is same too.
About Low resolution quality. Can we convert any video from low resolution quality to High resolution quality.
Tq
Real is a very low quality format in general.
No, low resolution cannot be magically improved to high resolution.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
So you start with a 720x576 DVD source and convert it to VCD at 352x288 MPEG 1 with VCD's low bitrate.Originally Posted by newbievideohelp
Then you take your over-compressed VCD file and over-compress it even more with Real codec.Originally Posted by newbievideohelp
Finally, you watch this low resolution, twice over-compressed, video on a bigscreen TV which digitally resizes the frame and magnifies all the over-compression defects. No wonder it looks terrible.Originally Posted by newbievideohelp
No. Go directly from your DVD MPEG source to Real codec (or even better, h.264) with no, or as little as possible, resizing.Originally Posted by newbievideohelp
I used directly convert from DVD MPEG to Real codec with Real Procedur but the result will be not a karaoke video file.
So what software can convert from DVD or VCD to Real codec with result karaoke real file, and support NVidia Cuda Encoder for fast process.
I tried use Mediacoder to convert any video file but failure. Where i can get Mediacoder userguide or information to convert DVD to VCD karaoke with Mediacoder.
tq.[/list]
I used directly convert from DVD MPEG to Real codec with Real Procedur but it not support DVD input.
I tried use Xilisoft directly convert from DVD to Real video file but the result is not a karaoke video file.
I'm not familiar with Real Producer or Karaoke Real files but did you convert the DVD VOB files to MPG files before trying to import them?Originally Posted by newbievideohelp
Regarding the Karaoke function -- is it just removing the vocals from the audio? If so, can you use the audio track from Karaoke VCD and the video track from the direct DVD to Real conversion?
Why anybody would convert anything to Real is beyond me.
Rip the DVD and convert it with VOB2MPG, then use a software player that has a "real" fullscreen function. If size is a factor then WME can produce very good results if you output 720x576. As was mentioned S-Video is a poor choice for a 16:9 HDTV, DVI or VGA is much better.
"I'm not familiar with Real Producer or Karaoke Real files but did you convert the DVD VOB files to MPG files before trying to import them?
Regarding the Karaoke function -- is it just removing the vocals from the audio? If so, can you use the audio track from Karaoke VCD and the video track from the direct DVD to Real conversion?"
What's tool to convert DVD VOB to MPG without reduce the resolution?
How to removing vocal and music from MPG video and how to use the audio track from Karaoke VCD and the video track from the direct DVD to Real conversion?"
"Why anybody would convert anything to Real is beyond me.
Rip the DVD and convert it with VOB2MPG, then use a software player that has a "real" fullscreen function. If size is a factor then WME can produce very good results if you output 720x576. As was mentioned S-Video is a poor choice for a 16:9 HDTV, DVI or VGA is much better."
I don't know what is video foramt file is better. But i just know real format will be small.
If so i use VOB2MPG to convert file, the resolution result will be reduce?
Tq
[/quote]
VOB2MPG, Mpeg2Cut2, TMPGEnc, Womble MPEG Video Wizard... All these tools simply remux the audio and video streams from a VOB file into an MPG file. There is no change of resolution or quality. VOB and MPG are simply "containers" that hold MPEG audio and MPEG video. All your doing is taking the audio and video out of one container and putting them in another.Originally Posted by newbievideohelp
I use TMPGEnc's demux and remux tools -- found under File -> MPEG Tools.Originally Posted by newbievideohelp
If you want small files you should consider using h.264 as your video codec. You can use a GUI front end to x264 like MEGUI, Xvid4PSP, x264GUI, etc. (all free). You can use MKV, MP4, or TS containers.
OK, after i from VOB to MPG with VOB2MPG.
Now, what's format is the best (smallest) if we want convert from this MPG without reduce resolution with can karaoke (like right sound and left sound for karaoke, the source file is karaoke file).
tq
Why do you need SMALLEST?
If you want BEST QUALITY at any given filesize and given runtime, you're really looking for the MOST EFFICIENT codec, and that's already been told to you: h.264.
You're also putting too much requirement on KARAOKE. Karaoke on VCD just means VOX-ONLY on one channel and VOX+MUSIC on the other, and you can use a number of tools to take MANY kinds of audio filetypes and mix them in the correct way to get what you want.
Tell us more of WHAT YOU HAVE TO START WITH, WHAT YOUR REQUIREMENTS ARE, and WHAT YOU NEED TO END UP WITH...
We understand that English may not be your primary language, but you're doing OK, just lay it all out for us.
Converting traditional Chinese subtitles to simplified
By Haopengyou in forum AudioReplies: 1Last Post: 20th Jun 2010, 10:40 -
low resolution
By rosmari in forum RestorationReplies: 19Last Post: 22nd Apr 2010, 17:23 -
Blu-Ray player with non-traditional 720p playback
By craigmack55 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Nov 2009, 13:20 -
Video Captured Low in Quality/Resolution
By kakashi123 in forum CapturingReplies: 4Last Post: 10th Jul 2009, 18:36 -
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 6Last Post: 27th Jan 2008, 05:03
