    Im using wondershare on my mac to store them on a external hardrive so i can bring it anywhere i go. I've been using apple tv mpeg-4 720x432 but was wondering if i use h.264 1280x720 will it be better quality. It seems to take about 2 times as long to copy the movies if i use h.264. Or is there a better format to use? Sprry if this is an easy topic.. im just kinda new to this and theres so much info on here i dont even know where to start...
    What is your source ?
    If it is SD (DVD or downloaded material) then there is nothing to be gained by upscaling to 1280 x 720. The quality will likely be lower, and if it is taking only twice as long, almost certainly the quality will be far lower.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    All my sources are my dvds.
    Then keep it simple and encode them as SD resolutions (i.e. 720 x nnn). Unless you are using a super-resolution type upsampler, simply resizing up to 720p resolution will do nothing by require far larger bitrates while producing a far softer image.
    I would still encode to H264 for the best quality/size, however I would probably use quality based encoding. Unless you are intending to play the files back on an Apple TV, I would avoid using Apple TV settings as they are of medium quality due to limitations imposed by the device.
    So the larger the bitrate the softer the images...
    Using the same dvd here are my options..
    mpeg 2 movie -- 720 ---- 4000 kbps
    avi xvid-----------640 ----- 1500
    m4v Mpeg 4 -----640 ----- 1500
    Mpeg 4 movie---640 ----- 1500
    Apple tv mp4 --- 720 ---- 1500 kbps
    appletv h264 --- 720----- 4000 kbps
    Are the larger file sized ones just wasting my time and theyre all just as good.
    I'm playing the movies back off of the external hardrive i have. I dont really care about the size of the files but just quality and time that it takes. Thanks again for your help!
  6. Always Watching guns1inger's Avatar
    Not the larger the bitrate. The softness of the image comes from enlarging to 1280 x 720.
    The only two I would question are the mpeg-2 files, where 4000 seems to be on the low side, but it depends on the actual video, and the H264 @ 4000, which seems high.
    If you convert the mpeg-2 to H264 then you can probably get away with 1500 or thereabouts.
    The Xvid/mpeg-4 (non-H264) material will only lose quality from being re-encoded, and probably doewsn't deserve a lower bitrate unless the quality is very low already.
  1. I need to choosing a video conversion format
    By Cralis in forum Newbie / General discussions
    Last Post: 17th Jan 2010, 03:59
  2. advice on choosing a format
    By broox in forum Newbie / General discussions
    Last Post: 10th May 2005, 22:48
  3. How to convert licensed files into DVD format
    By Carpetmancol in forum Newbie / General discussions
    Last Post: 1st May 2005, 08:01
  4. Choosing a multi format DVD player
    By StealthKing in forum DVD & Blu-ray Players
    Last Post: 12th Jun 2004, 01:58
  5. Choosing the capturing format
    By rodrigues in forum Capturing
    Last Post: 31st Jul 2003, 23:21
About   Advertise   Forum   RSS Feeds   Statistics   Tools
