DTS and AC3 are the two types of audio. I only have Divx Preview installed on Windows 7. What do I need to install to get audio working? I really would like to avoid using codec packs
Results 1 to 10 of 10
Do you also have an ac3 decoded installed? That fixed my audio problems.
You might try AC3Filter. It should handle your AC3 and DTS. And if you need other commonly used codecs, you might try ffdshow. It's not a codec pack, but it supports quite a few codecs. And it doesn't cause problems like codec packs can.
And just for general playback, try VLC player. It has it's own codecs and plays most formats without having to install anything else.
Sorry for the late follow up.
I tried ffdshow but I didn't get any audio. Am I supposed to do anything more to get it working?
Anyone?
Have you tried playing it in vlc as redwudz suggested? Also try mediaplayerclassic - there is a cinema version that can readily do high def files. Both free to use - they work on vista so I"m assuming they work on windows 7 or will soon with an update.
Open "Audio decoder configuration" from ffdshow's Start Menu folder, and highlight 'Codecs' in the left-hand pane of the configuration window that pops up. Scroll through the list of codec/formats on the right. Are any of the choices for AC3 and DTS (as well as any other format that might apply, here), set to 'Disabled' under the 'Decoder' column?
Nope. I switched to x64 and still can't hear anything. Not disabled so not sure what is going on
FYI - I gave up on getting this to work and installed Shark007's codec pack. Working like it should now
Subtitle Workshop not showing mkv files during preview
By tuna1013 in forum SubtitleReplies: 8Last Post: 30th Dec 2011, 12:58 -
Blueray player with mkv, xvid, divx, avi, etc... support. Advice please!
By szabo_77 in forum DVD & Blu-ray PlayersReplies: 27Last Post: 8th May 2011, 20:53 -
Best BluRay player with MKV, DivX, XVID, etc... support. ADVICE PLEASE!
By szabo_77 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Apr 2011, 16:13 -
Any reason why most dvd player only support xvid, divx and not rmvb and mkv
By c1steady in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2009, 19:14 -
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 04:31
