i have a powerpoint presentation. how can i put it on dvd
Screen capture = Camstudio
See the tools section for others:
http://www.videohelp.com/tools/secti...screen-capture
or
PPT to Video = http://www.effectmatrix.com/PowerPoi...-Converter.htm
This works okay, but the freeware version is limited to mpeg1.
Authorstream.com can convert to video and you can use DVDFlick to author a DVD:
http://www.online-tech-tips.com/comp...dvd-flash-pdf/
A note about Camtasia:
Although it's a great program it's output files cannot be used with DVDFlick(for whatever reason).
I and others have had much discussion about this. Lots of options...Do a search on this site.
Have a look > http://www.freewaregenius.com/2008/1...-dvd-for-free/
Having used E.M Free Powerpoint Video Converter I recommend mpeg1 but resize for full dvd specs ... use mpg2cut to edit out useless garbage and save as new file ... bang into dvdflick ... no water mark
moviegeek,
i dont ssee any option on a uthorstrem to upload an audio file, how do you do it or can you?
bjs:
I tried to use em free ..... but it seems to just go in a loop, the progress bar starts off and goes to the end and then repeats along witha repetition of the slideshow audio. Is this normal
http://upload.authorstream.com/multipleupload/
In order to download the video the presentaion has to be less than 45min and have narration set to start automatically. The free version has a ad logo but you can pay $2 for a non-logo version. The video converter mentioned above may be easier to use.
Nope but check power point presentation ... from 2003 powerpoint "loop" option was viable unless esc is pressed ... that could cause the problem.
How to add a DVD video to a Powerpoint Presentation
By andy jackson in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 12:27 -
Question about cutting clips for a Powerpoint presentation
By tanealbhandari in forum Newbie / General discussionsReplies: 16Last Post: 10th Dec 2008, 10:38 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2008, 23:59 -
Which video format works best in a PowerPoint Presentation?
By foochuck in forum Video ConversionReplies: 1Last Post: 4th Oct 2007, 09:54 -
How can I Put PowerPoint on a DVD?
By jrhx in forum Authoring (DVD)Replies: 38Last Post: 26th Jun 2007, 13:07
