hi
i know how i can get the subtitle from mkv video but i want to know how i can get subtitle from avi-wmv-mp4...
can any one help me please!!!!
Hello to evry one
If they are burned in subtitles you must use some OCR program like AVISubDetector.
If they are switchable use yamb for mp4 and virtualdubmod for avi. I'm not sure if wmv can embed switchable subs.
virtualdubmod give only time not subtitle can you help me please
Hello to evry one
In VirtualDubMod, with the video loaded, go to the Streams menu and select 'Stream list'. Is the subtitle stream listed there?
i openning VirtualdubMod i get the movie in avi format i go to streams - streams list but i find just the audio no subtitle
Hello to evry one
The subtitles are most likely burned into the video (hardsubs = a part of the video data itself rather than a separate, easily extracted stream), then, and the only way to 'extract' them is to use an OCR program like Baldrick suggested, above.
any programs work for me i can't get the subtitle from avi
Hello to evry one
Have you tried using AVISubDetector?
Be warned that OCRing burned-in subtitles is not a quick, simple or automatic process, generally. You might be better off just running a web search for another set of subtitles for that particular video.If cameras add ten pounds, why would people want to eat them?
Subtitle not Apper in Video
By kdscreations in forum SubtitleReplies: 1Last Post: 10th Nov 2011, 05:32 -
make subtitle for learning video
By seyyed in forum SubtitleReplies: 1Last Post: 2nd Oct 2011, 08:06 -
the video cant play with the subtitle
By TheEmperor in forum Software PlayingReplies: 4Last Post: 20th Sep 2009, 18:00 -
The best Video Subtitle.
By TopZoom in forum SubtitleReplies: 6Last Post: 14th Nov 2008, 09:35 -
How to add subtitle to a video
By Chuba753 in forum SubtitleReplies: 7Last Post: 7th Jun 2008, 21:31
