VideoHelp.com Forum
    Hi. I have many .m2ts files that I need to join and additionally add transitions like title pages and such. For instance, I would like to be able to join them and then have a timeline where I can add transitions. I have found tsMuxeR which successfully joins the movies, but I can not add transitions with it. I do want to preserve the high quality of the video rather than converting to some other format/resolution. Can anyone suggest software which can do this? I don't mind if I have to pay for it so long as it has the features described above namely:
    m2ts joining and transitions between clips and at the beginning/end of the clips.
    Thanks.
    m2ts? avchd camera or from blu-ray?
    How much are you willing to spend?
    Try google for smart rendering avchd or m2ts. Read also http://www.avsforum.com/avs-vb/showthread.php?t=880825
    smart rendering = it does not reconvert the entire clip.
    I'm hoping to spend no more than $50, the cheaper the better though. The video comes from a AVCHD camcorder: Panasonic HDC-HS9.
    Thanks for the links.
  1. Replies: 6
    Last Post: 28th Aug 2011, 17:44
  2. Joining m2ts files
    By theendisnye in forum Authoring (Blu-ray)
    Last Post: 21st May 2011, 11:51
  3. Adding transitions to videos with free software
    By Cyber Akuma in forum Editing
    Last Post: 8th Dec 2010, 11:36
  4. Replies: 0
    Last Post: 23rd Oct 2010, 17:56
  5. tsMuxer and joining m2ts files
    By fkasparek in forum Blu-ray Ripping
    Last Post: 22nd Jun 2009, 20:31
