I've a problem with encoding video file by ffmpeg. I want to have file like this:
And I don't know which options in ffmpeg use to make it. FFmpeg every try gives me all I want except simple profile llevel 3 or except packed bitstream.Code:Format : AVI Format/Info : Audio Video Interleave File size : 116 MiB Duration : 42mn 51s Overall bit rate : 379 Kbps Writing application : VirtualDubMod 1.5.10.1 (build 2439/release) Writing library : VirtualDub build 23567/release Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 42mn 51s Bit rate : 314 Kbps Width : 624 pixels Height : 352 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.060 Stream size : 96.2 MiB (83%) Writing library : XviD 1.1.0 Beta2 (UTC 2005-04-04) Audio ID : 1 Format : MPEG Audio Format version : Version 2 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 42mn 51s Bit rate mode : Constant Bit rate : 56.0 Kbps Channel(s) : 2 channels Sampling rate : 24.0 KHz Resolution : 16 bits Stream size : 17.2 MiB (15%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 500 ms
Could someone help me?
try don't use bframes (-bf 0)
BHHHDConvertToX, AutoMen, AutoMKV Developer
With -bf 0 i don't have Format settings, BVOP so i have to use -bf, i have a problem with force ffmpeg to packed bitstream and everything except this is OK
How to enable Packed bitstream
By john111 in forum Video ConversionReplies: 8Last Post: 4th Jan 2010, 14:17 -
it is safe to use Packed Bitstream on Xvid
By afcoff in forum Video ConversionReplies: 8Last Post: 6th Mar 2009, 07:43 -
adding packed bitstream to xvids
By pace508 in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2009, 16:10 -
Any new DVD DivX players which handle packed bitstream smoothly?
By tzikeh in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Dec 2007, 19:13 -
Help with MPEG Modifier... Packed Bitstream...
By GangstaRap in forum Newbie / General discussionsReplies: 0Last Post: 24th Dec 2007, 12:14
Statistics
Newest guides
Latest tool updates
New media comments
