    I want to backup dvd movie (main movie only) , size 6.5G or more to single layer dvd disc (4.3G)
    Which way remains the best quality ?
    for example, using dvdshrink makes 1 move only disc (compress rate = about 65%?)
    Or I can reencode the main movie using automkv and make SL-DVD including mkv file.
    But I don't know which remains the better quality (of course worse than original, I know).
    And, another question.
    Automkv does not support windows 7 or 64 bit windows.
    Are there any tool that can produce mkv and resize to single disc and support windows 7 64bit ?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    DVD Rebuilder is another option if you want to produce a DVD playable on most set top players with usually better quality than DVD Shrink. Shrink is fine if you can use minimal 'shrinkage', but with higher percents, DVD Rebuilder is a better choice.
    I'll let someone else answer the MKV question. MKV is generally more suited for computer playback.
    And welcome to our forums.
  1. 2-disc movie->single DivX file
    By briansmccabe in forum DVD Ripping
    Last Post: 9th Dec 2005, 11:04
  2. Replies: 20
    Last Post: 8th Jan 2005, 07:06
  3. Replies: 13
    Last Post: 17th Dec 2003, 19:34
  4. Backup DVD9 to single VCD
    By panae50 in forum DVD Ripping
    Last Post: 5th Oct 2003, 07:49
  5. Dvd rip 120 min movie DVD9 disc
    By birdygal in forum DVD Ripping
    Last Post: 29th Dec 2002, 23:00
About   Advertise   Forum   RSS Feeds   Statistics   Tools
