I have exported a video from Premiere Pro CS4 in various formats, e.g. wmv and flv. These work fine locally but not online. I have fpt'ed them to my web site using Wise FTP but MediaPlayer gives me:
"Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file."
If I download the flv version Realplayer plays a couple of seconds but is very pixlated or a still image. Again, it's perfect locally.
I have tried several times, in case the file was corrupted, with different files and formats but NFG. Oddly, my older files (mov, avi, wmv) on the site work fine.
Help gratefully received before I lose consciousness from banging my head against the wall.
UPDATE:
Just tried converting with AVS Video Tools and it works fine when downloaded. So it looks like something to do with Adobe Media Encoder but what?
for online flv you might try flash player, applian flash player, flv player, or vlc. mwp and rp aren't good for it.
Thanks for the suggestion but I'm trying to get it to work for general viewing so don't want it to be fussy. Oddly, now I have loaded my registered version of AVS, re-uploaded the video it doesn't work. The same as it was from Adobe Encoder, so maybe it's a problem with the upload or my web space?
This used to work OK and I have uploaded lots of video in different formats to the same site using the same s/w. FOr some unknown reason it has stopped working. I have even tried uploading from a different PC. -
are you trying to get them to stream off the website like youtube? or right click a link/save-as download a file then play them?
maybe your ftp upload software has a problem? give filezilla a try, free and the best i've used. because if they play fine before uploading there shouldn't be any problem after the d/l, it should be the exact same file. -
Just tried again on my other PC and it worked fine this time using Wise FTP. Weird. Will try on original PC and reload Wise if I have a prob. Cheers!
Free Video Dub-Trim runs too fast
By rosmari in forum EditingReplies: 2Last Post: 19th Nov 2011, 10:14 -
mp4 plays fine locally, sucks at streaming
By Frustrated One-Off in forum Video Streaming DownloadingReplies: 1Last Post: 10th Sep 2010, 14:01 -
installing codec locally...
By proxima centauri in forum ProgrammingReplies: 2Last Post: 21st Apr 2010, 08:17 -
Do you stream your media or play it locally on a physical device?
By yoda313 in forum PollsReplies: 15Last Post: 19th Jun 2009, 21:03 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 17:45
