i have controverted this clip 6 times already and getting (no disk- unknown disk ) in my dvd player
it has h 264 codec
I have AVIcodec that tells me what codecs are used on clips
but the video codec name is unknown
I have tried a few programs like handbreak - total video converter and few others
but it seems that I can' decode or convert this one over
simple question what is the standard resolution for dvd players 720x480?
Results 1 to 30 of 96
Thread: H 264 conversion
The NTSC DVD spec calls for 720x480, 704x480, 352x480, or 352x240 MPEG 2.
Guess you couldn't find the "WHAT IS DVD" link in the top left column of this website.
NTSC (that means Canada) DVD must be 720x480 or 352x480 or in very rare circumstances (you'll have to make these yourself) 352x240. PAL DVD supports 720x576 or 352x576 or 352x288 (again, you'll have to make that last one yourself to see it).
ok then
I guess i'm doing something wrong when trying to decode or convert
i have resolution set at 720x480 and aspect ratio is set at 16:9
the original file has 768*432 (16:9), H264 = Unknown, Supported (AVIcodec)
yes i'm aware of dvd resolution but for the past few days I have gotten my self mixed up trying to get a clip to play in stand alone that has H 264 codec
So i thought the resolution is off
I'm the type of person that frustration hit's in 2 mins of trying to decode or covert
I forgot 704x480 (704x576 is the PAL equivalent) that jagabo mentioned.
Ok so I ahve the resolution
But I'm stuck on not being able to decode or convert
cause of this 768*432 (16:9), H264 = Unknown, Supported
I'm confused. What exactly do you want your end-product to be? Are you trying to make a DVD (with VIDEO_TS and AUDIO_TS folders) out of a video file?
no the end-product is avi with xvid or divx
the file is already avi which has H 264 codec and won't play on stand alone
I have done this before decode and convert these files but this one is trying my Patience's
Every time I convert it then play it - I get this on dvd player (no disk - unknown disk)
even after I use AVIcodec to look at the end product
this is the original file has 768*432 (16:9), H264 = Unknown, Supported
and this is my end product 23.976 fps, 720*480 (4:3), XVID = XVID Mpeg-4, Supported
so when i play it in dvd player it says (no disk or unknown disk )
this is were i'm stuck
Everybody in this thread thinks you are going from a video file to DVD. Slow down and start again. What tools have you used so far to try to go from this file to xvid/divx?
I have used these tools
handbreak
AllToAVI
Xilisoft
Any video converter
Total video converter
The original file is an avi file with H 264 codec (that codec is supported in some dvd players - but not mine )
So I have been trying to decode or convert this file with a xvid or divx codec
I'm far from an expert in H264/X264 but....I don't see that many of those tools even mention H264. Run that file through GSpot and see what it tells you....if you haven't already.
here is the H 264 codec ITU H.264
that Gspot found thx for that hech54
Long story to short this is what I'm trying to do
how to convert H264 to Xvid or Divx. for standalone dvd player
My personal faves as far as software go are AviDemux(ignore the name....it has very little to do with demuxing) and VirtualDub. I'm going to download a sample of H264 right now and give it a go.....I'm curious too.
H 264 codec is not supported in any home dvd player,just blu-ray,do you have the codecs installed to encode such as ffdshow and haali media splitter?Originally Posted by RussoBen Johnson-I didnt take any stereos!
He already knows that. He it attempting to convert it to Xvid - Divx.Originally Posted by johns0
I downloaded a HUGE(1280x544)H264 sample movie trailer. I opened it in AviDemux(the QT4 version but I'm sure it will work in the regular version)...ignored the warnings....resized the video down to 720x304 and converted it to Xvid with MP3 audio and it plays, looks and sounds perfect in VLC Player and Windows Media Player.
The warnings in AviDemux were alerting me to the fact that I will basically lose accurate editing capabilities....no big deal in this case.
Originally Posted by hech54He did say this.Originally Posted by RussoBen Johnson-I didnt take any stereos!
How about loading the file in xvid4psp, selecting "AVI Hardware profile" and converting it?Originally Posted by Russo
The result will be a MPEG4 AVI encoded file that is compatible on most DVD players.
hech54 after u used AviDemux did u try it in a stand alone to see if it would play?
See I have done this before 4 other times but this time it's not working same settings same program
this is what I had used Xilisoft simple to use takes about 1hour to do the job.
But what I have done last night was find the missing codec that AVIcodec couldn't identify (missing codec ITU H.264 )
I also have ffdshow and haali media splitter? installed but don't know how to use them atm.
So I will try anything or any program
I won't give up this has been done before and I will do it again
My DVD player does play Xvid/Divx....and i did save the test output. Let's see if my player likes CD-RW...shall we?
I loaded the test file into my Trekstor HDD media player(which only plays Xvid/Divx with MP3 audio) and it plays perfectly. Loads fast and plays without a hitch.
ok so u used AviDemux to convert thefile then played it in a stand alone dvd player right?
Yes....here is my test file:Originally Posted by Russo
http://www.zshare.net/video/6657362057065911/
24MB
And here is the original sample clip I used.
http://www.h264info.com/clips.html
The very first one...
Video Type: 1280×544 (720p), 23.967 FPS, CE-QuickTime profile
Audio Type: AAC HC Stereo
ok will give it a try tonight and will post in the morning
I am playing with the AviDemux program
and can't seem to find the resize option
Video (section) -> Filters (button) -> Transform -> ResizeOriginally Posted by Russo
ok ty going to take a bit for me to play with this it's all new to me
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
.264 Conversion
By thunderclap82 in forum Video ConversionReplies: 4Last Post: 11th Mar 2010, 17:48 -
Looking for H.264 conversion help
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 24th Nov 2009, 05:19 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 06:47 -
MPEG1 to H.264 conversion
By sarvagya in forum Video ConversionReplies: 5Last Post: 14th Dec 2007, 03:25
