Hello everyone,
I have a problem with subtitles and have found threads about this but not a solution.
Both the subtitles that I downloaded and subtitles that I made in Subtitle Workshop don't display properly
on video and DVD players. The subtitles are in Croatian and letters č; ć đ are displayed as è æ ð. Š and ž are okay.
The subtitles are in srt format but I have tried saving the ones I made in ssa and the same problem occurs.
The Subtitle Workshop is set to EastEurope and when I tried ANSI they were not shown correctly inside Workshop.
If someone can tell me how to fix this I'd be grateful as I don't know where else to look.
Thank you,
Ivana
Welcome atai
Check these settings ... the font being used must support those characters
Alt + s > Look > Program
Default is Tahoma 8 (centered)
ANSI : ANSI : DEFAULT ... saving in srt and ssa format is no problem here.
There are dvd players manufactured with issues which can be corrected either manually or by updated firmware.
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 02:20 -
Photos don't show after burning
By better life in forum ComputerReplies: 3Last Post: 23rd Dec 2009, 19:28 -
srt subtitles don't display properly
By briligg in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2009, 13:12 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
dvd movies don't screen on monitor properly are split into 3 sections
By beachychick in forum Software PlayingReplies: 3Last Post: 29th Oct 2007, 19:03
Statistics
Newest guides
Latest tool updates
New media comments
