I'm trying to demux the sound from a m2ts file (kung fu panda). When I load it in tsMuxer it shows that the main file's track sound is ac3 core + true-hd. I tried to demuxing the file so I can then convert it to standard ac3 using ac3to. The problem is when I try to do this the output file that tsMuxer gives me is only ac3 and it's not proper, it seems that chunks of audio are missing, not that the audio cuts off but that some sounds aren't there....like the panda falling down the stairs, and it gets out of sync.
Here it is the screenshot of what I'm doing.
As you can see I loaded the m2ts file, unchecked all the tracks except the ac3 core+ True HD and then I press demux.
Am I doing anything wrong? Should I use other software?
When I try to dowmix the audio track to ac3 directly using tsMuxer it give's me an overflow error.
Note: My OS is windos 7 x64.
Thanks in advance
looks like your doing it right. try to demux using another piece of software. Try clown_bd and see if you get the same result. i've demuxed alot fo bluray titles for archiving purposes and ive converted all the new HD audio streams to just straight 640 ac3 audio due to my MVIX Ultio not yet able to decode the newer audio.
You can try eac3to, it fixes audio gaps, delays etc...
But using eac3to don't I need to individualize the audio file? I mean can it work with m2ts input and then convert the audio directly?
Many thx for the help
Dude, check the h.264 box and downconvert in tsMuxeR, TsMuxer will demux, down convert the audio, and multiplex the streams for you, and be done w/ it
TsMuxer does everything you want w/o "help" from any other program, and the latest version fixs overlaps and gaps too
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
I tried that but it gives me an error saying "Reading buffer overflow" and I realy don't know what others programs to use...clown_bd tells me that the file format is not recognized (eac3to error).Originally Posted by ocgw
I just want to convert true HD 5.1 to ac3 so I can run the movie on my media center properly. Thx
sorry for resurrecting a dead thread...but you can use eac3to to convert a True-HD audio format to AC3.
Just you don't need to do anything special in the settings...just select your "Save Type As" as being AC3 and you're good to go.
And no, you don't need to demux the audio you want from the primary stream file prior to conversion.
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 5Last Post: 31st Dec 2011, 08:02 -
How to convert AC3 True-HD to DTS ?
By Kernell in forum AudioReplies: 5Last Post: 28th Nov 2011, 19:42 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
How to burn avi file with true 5.1 ac3 sound on dvd?
By namesake in forum Video ConversionReplies: 17Last Post: 20th Mar 2009, 10:49 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 14:06
