VideoHelp.com Forum
Closed Thread
    We know that Premiere Pro CS4 does not support XDCAM and AVCHD formats because, unlike most professional video editing softwares, it doesn’t export them (you have to buy very expansive Mainconcept plug-in to do it).
    This problem is increased by another one, which is even worse : unlike for example Edius Pro and Final Cut Pro, which include for free essentials intra-frame editing codecs (Canopus HQ for Edius and ProRes for Final Cut…) to correctly edit HD videos (XDCAM, HDV, AVCHD…), Premiere Pro CS4 does not : in order to edit HD videos with Premiere Pro CS4 (except P2 from Panasonic which is supported by Premiere), no choice but to buy Cineform codec whose price is 499 $ minimum ( http://estore.cineform.com/index.aspx ) !!
    It was important to communicate this information which shows Premiere Pro CS4 only supports non-HD formats (+ P2 from Panasonic), because it is not said at all on Premiere Pro CS4 documentation.
    Here we go again. You already started this subject thread once:
    http://forum.videohelp.com/topic372701.html
    Your questions were answered (perhaps not to your satisfaction); your misguided conclusions about Premiere CS4 were straightened out (we thought); and we tried endless explanations to get the concept through your skull -- but to no avail, apparently.
    I don't know what else you want us to do for you. Perhaps nothing. Perhaps you are just obsessed with slamming Premiere. Whatever the case, this is getting VERY tiring.
    Countless others edit HD in CS4 all the time with no problems. Did it occur to you that the issue may be with the user, and not the software?
    CS4 edits HD formats just fine.
    If you want to do some uncommon export feature, use software for that task.
  4. Member fitch.j's Avatar
    Quoted for emphasis!
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    One similar topic is enough . http://forum.videohelp.com/topic372701.html
  1. Premiere Pro Cs4 exporting issues
    By gooberguy in forum Editing
    Last Post: 27th Jan 2011, 21:15
  2. Using Premiere CS4 to edit Ripped Clip
    By jbandy1 in forum Blu-ray Ripping
    Last Post: 15th Nov 2010, 10:34
  3. Need help on premiere pro CS4
    By george2005 in forum Editing
    Last Post: 27th Mar 2010, 04:42
  4. Premiere Pro CS4 AVCHD Presets?
    By petronas in forum Newbie / General discussions
    Last Post: 6th Jan 2010, 01:59
  5. Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
    By vid83 in forum Newbie / General discussions
    Last Post: 22nd Feb 2009, 17:10
