Hi, I have an mkv file that won't play on my computer.
My PC is Dual Core 1.6 GHz, 1 GB RAM.
I've tried install the K-Lite Codec Pack, CCCP community pack.
The Media info is:
General
Format : Matroska
File size : 701 MiB
Duration : 2h 29mn
Overall bit rate : 654 Kbps
Movie name : devise-transfbr
Encoded date : UTC 2009-09-27 02:11:28
Writing application : mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:31
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 29mn
Nominal bit rate : 523 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.100
Writing library : x264 core 75 r1251M e553a4c
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-2 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=523 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : A_AAC
Duration : 2h 29mn
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Can someone help me?
Thx
Results 1 to 13 of 13
Thread: Can't play mkv
You need the Haali Media splitter or Gabest Matroska splitter to playback these types of files, or download a codec pack or VLC media player
Check if your file is corrupted.
Uninstall k-lite and ccp and install ffdshow and Haali Media splitter instead.Use media player classic to view mkv files.
Ben Johnson-I didnt take any stereos!
Installing multiple codec packs is a bad idea. They may conflict.
K-Lite should have everything you need. (No comment on CCCP, haven't used it.)
K-Lite includes Media Player Classic. Can it play the file?
Can it play other MKV files?
If not, go back to K-Lite's config and see if it activated Haali Media splitter; it should have by default.
Media Player Classic-Home Cinema is better choice for MKV playback. It has added features for MKVs over the plain MPC.
Some on-board video chips are also marginal for MKV/HD playback.
And when you say it 'Cant play..', does it do anything, even play a few frames? VLC should be able to play it with no codec packs added. But VLC may skip a little if you don't have sufficient processing power.
I'm using Media Player Classic from K-Lite.
Not all mkv files playable on my PC, some play, some don't
That's the version included in the current K-Lite.Originally Posted by redwudz
You should get some kind of error message. If so, what is it?Originally Posted by quanz
No error message, I double click the file to play, Media Player Classic start and immidiately pause at the very end of the video. When I click the Play button again, nothing happens.
Interesting. A codec pack that includes a player that doesn't need a codec pack.Originally Posted by AlanHK
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
You still need codecs installed if you need to encode but if not Media Player Classic-Home Cinema will be enough.Originally Posted by neomaineBen Johnson-I didnt take any stereos!
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 51Last Post: 1st Dec 2011, 06:10 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 1Last Post: 6th Jul 2009, 13:45 -
some .mkv won't play
By snooze091 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 18:48 -
can anything play .ogm or .mkv
By ChokeUntilDead in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Nov 2005, 22:17 -
MKV File will not play
By is_matrix in forum Newbie / General discussionsReplies: 5Last Post: 11th Sep 2004, 15:40
