This one is just so odd that if I hadn't seen it with my own eyes I'd never believe it.
I do a lot of temporary burns onto DVD-RWs with episodes of TV shows. For this I have a default menu with a background bitmap and I manually set the font to Tahoma, Bold Oblique, 24 point each time. Most times each disc ends up with three or four episodes. Occasionally it's just the one episode but either way I align all of the text 'buttons' vertically (if there's more than one) then use the centre horizontally and centre vertically buttons to put everything in the middle of the 16:9 frame.
Yesterday I tried doing this with a single episode and SVCD2DVD crashed during the Encoding Menu phase. The whole program just disappeared, interface and all. At first I thought this must be a problem with the video itself so I tried trimming the temporary MPG file and trying again, but it still crashed. Then I tried obtaining another copy of the *ahem* 'source' AVI and started again. Still it crashed.
This could have continued all day but during one of the many attempts I accidentally forgot to set the font to Tahoma, Bold Oblique 24 and SVCD2DVD reported success. Not quite able to believe how a font setting could upset the disc creation I tried again with the font set how I normally do things, and it crashed.
I tried again with the almost the same settings but with the font set to 26 point. The disc was created successfully. Then I tried again with a different font. Success. Then I set it for Tahoma, Bold Oblique 24 but added an extra character to the episode title. Success. Finally I tried the original title, Tahoma Bold Oblique 24, but offset the button from exact centre. Incredibly, it succeeded again. Just to make sure I wasn't going nuts I put everything back the way it was with the button centered, and it crashed.
There must be a unique combination of character length, font size, button position and possibly the background bitmap that's causing an internal problem for SVCD2DVD or one of the other programs whose functions it calls. I'm attaching a couple of log files, one from a successful run with the menu text offset and another from a bad run with the text centred.
Hopefully someone here can translate these log files better than I can and help come up with an explanation. The only difference I can see is in the HERE WE GO EVE.ODD section where the 'bad' configuration leads to a couple of zeroes while there aren't any in the 'good' configuration. I don't know exactly what's going on here but zeroes where there shouldn't be generally don't bode well in computing!
As you can see, the final line of the 'bad' log shows a missing temporary file. I'm guessing it's this that's causing SVCD2DVD to fall over, but it would be nice to know exactly what the mechanism is that's leading to it. The workaround is obvious -- if it crashes, move the text and try again -- but I abhor mysteries. In many years of using this program with these or very similar settings this is the first time I've seen such a thing happen.
Anyway, here are the logs. First the working configuration...
...and now the one that crashes...Code:******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** SVCD2DVD ***************************** Name: SVCD2DVD 2.5 Title: 2.5 Version: 2.5.5030.0 Executable: C:\Video\SVCD2DVD\SVCD2DVD.exe Executable size: 2.58 MB Executable size in bytes: 2711635 Executable CreationTime: 28/01/2009 15:57:36 Executable LastWriteTime: 23/08/2009 15:24:09 Executable LastAccessTime: 23/08/2009 15:24:09 ************************* Operating System ************************* Operating System: Microsoft Windows 7 Ultimate Service Pack: Version : 6.1.7100 Windows Directory : C:\Windows OSLanguage: 1033 CodeSet: 1252 CountryCode: 44 Local: 0809 Total Physical Memory: 3.99 GB Free Physical Memory: 2.48 GB Total Virtual Memory: 7.99 GB Free Virtual Memory: 6.20 GB ***************************** Computer ***************************** Computer Manufacturer Name: HP-Pavilion Computer Model: KZ756AA-ABU m9351.uk System Type: x64-based PC Computer Name: REDACTED DomainRole: x2c3419cdc9b8e007 Number Of Processors: 1 User Name: REDACTED\REDACTED ***************************** Processor **************************** Manufacturer: GenuineIntel Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Description: Intel64 Family 6 Model 15 Stepping 11 CPU Speed: 2.4GHz CPU FSB: 1.066GHz L2 Cache Size: 8.00 KB 15:11:03: Logical CPUs: 4 ***************************** Time Zone **************************** Time Zone: (UTC) Dublin, Edinburgh, Lisbon, London ****************************** VIDEO ******************************* Name: NVIDIA GeForce 9600 GSO 512 Processor: GeForce 9600 GSO 512 Mode: 1440 x 900 x 4294967296 colors Video Ram: 1.00 GB Status: OK ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 39.9 GB FreeSpace: 7.08 GB DeviceID: D: FileSystem: NTFS Size: 425 GB FreeSpace: 132 GB DeviceID: E: FileSystem: NTFS Size: 312 GB FreeSpace: 29.8 GB DeviceID: F: FileSystem: NTFS Size: 153 GB FreeSpace: 52.5 GB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ************************* ProjectMetaData ************************** <?xml version="1.0" encoding="utf-8"?> <SVCD2DVD DateTime="03/10/2009 15:11:04" Filename="NONE"> <AssetSet> <Asset ID="3921fbae-49e9-4d7b-af3f-040a8005a408" Path="F:\" Filename="5x03 - The Plain In The Prodigy_S2D.mpg" /> </AssetSet> <DVDStructure> <TitleSet Name="5x03 - The Plain In The Prodigy" PostCmd="" MenuButtonType="0"> <MenuButton X1="159" Y1="158" X2="693" Y2="204" FontFamily="Tahoma" FontSize="24" FontStyle="3">5x03 - The Plain In The Prodigy</MenuButton> <Title Name="5x03 - The Plain In The Prodigy_S2D.mpg" AssetID="3921fbae-49e9-4d7b-af3f-040a8005a408" MplexOffset="0" /> </TitleSet> <DVDMenu Normal="-4144960" Highlight="-1" Active="-16777216" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="F:\Projects\Metallic.bmp" AudioPath="" /> </DVDStructure> <Settings> <General InitialAssetFolder="F:\" InitialDVDFolder="F:\" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="F:\Projects" InitialMenuBackgroundFolder="F:\Projects" DeleteS2DFiles="False" UseDVDShrink="False" /> <Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="F:\Projects\Metallic.bmp" TVStandard="NTSC" FontFamily="Tahoma" FontSize="15.75" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="True" MenuAspectRatio="AR_16_9" /> <Process AudioEncoding="ac3" Chapters="Every 5 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" /> <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /> <Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /> </Settings> </SVCD2DVD> ************************* ProjectMetaData ************************** Processing assets for DVD creation =================== AV Details =================== File Size: 2.17 GB file=F:\\5x03 - The Plain In The Prodigy_S2D.mpg FormatName=mpeg Num_Frames=62000 DurationInSecs=2586 Duration=00:43:05.9 VideoCodec=mpeg2video VideoFFSTNum=0 Width=720 Height=480 Standard=NTSC BitRate=7240 AudioStreamCount=1 Audio1FFSTNum=1 Audio1StreamID=[0x80] Audio1SampleRate=48000 Audio1Codec=ac3 Audio1BitRate=448 Audio1Channels=6 =================== AV Details =================== 15:11:04: Leaving 5x03 - The Plain In The Prodigy_S2D.mpg alone. File has Nav Packs 15:11:06: Done: Processing assets for DVD creation Authoring DVD Folders 15:11:06: Creating TitleSet # 1 15:11:06: SVCD2DVD: DVDfolders Generating DVD folders please wait.... 15:11:06: -->: DVDFolders creating VTS 15:11:06: -->: VTS 01 15:11:06: DVD Folders: Processing C:\Video\SVCD2DVD\dummymenuNTSC.mpg... 15:11:06: DVD Folders: Processing F:\5x03 - The Plain In The Prodigy_S2D.mpg... 15:12:19: 15:12:19: 15:12:20: 15:12:20: Finalising DVD... 15:12:20: Encoding menu... ---------------------------- ENCODING MENU ---------------------------- TV Standard: NTSC Aspect Ratio: 16:9 Image size: 960x540 Resize size: 720x480 ---------------------------- ENCODING MENU ---------------------------- [] 15:12:20: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al. [] 15:12:20: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices [] 15:12:20: libavutil 49.12. 0 / 49.12. 0 [] 15:12:20: libavcodec 52. 6. 0 / 52. 6. 0 [] 15:12:20: libavformat 52.23. 1 / 52.23. 1 [] 15:12:20: libavdevice 52. 1. 0 / 52. 1. 0 [] 15:12:20: libswscale 0. 6. 1 / 0. 6. 1 [] 15:12:20: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502 [] 15:12:20: Input #0, image2, from 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\background1.jpg': [] 15:12:20: Duration: 00:00:00.04, start: 0.000000, bitrate: N/A [] 15:12:20: Stream #0.0: Video: mjpeg, yuvj420p, 720x480 [PAR 96:96 DAR 3:2], 25.00 tb(r) [] 15:12:20: Output #0, rawvideo, to 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\backgroundES.mpv': [] 15:12:20: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=2-31, 6000 kb/s, 29.97 tb(c) [] 15:12:20: Stream mapping: [] 15:12:20: Stream #0.0 -> #0.0 [] 15:12:20: Press [q] to stop encoding [] 15:12:20: video:49kB audio:0kB global headers:0kB muxing overhead 0.000000% 15:12:20: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $) 15:12:20: INFO: [???] File C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv looks like an MPEG Video stream. 15:12:20: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options! 15:12:20: INFO: [???] Found 0 audio streams and 1 video streams 15:12:20: INFO: [???] Selecting dvdauthor DVD output profile 15:12:20: INFO: [???] Multiplexing video program stream! 15:12:20: INFO: [???] Scanning for header info: Video stream e0 (C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv) 15:12:20: INFO: [???] VIDEO STREAM: e0 15:12:20: INFO: [???] Frame width : 720 15:12:20: INFO: [???] Frame height : 480 15:12:20: INFO: [???] Aspect ratio : 16:9 display 15:12:20: INFO: [???] Picture rate : 29.970 frames/sec 15:12:20: INFO: [???] Bit rate : variable 15:12:20: INFO: [???] Vbv buffer size : 212992 bytes 15:12:20: INFO: [???] CSPF : 0 15:12:20: INFO: [???] SYSTEMS/PROGRAM stream: 15:12:20: INFO: [???] rough-guess multiplexed stream data rate : 0001248 15:12:20: INFO: [???] target data-rate specified : 10080000 15:12:20: INFO: [???] Setting specified specified data rate: 10080000 15:12:20: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 15876 15:12:20: INFO: [???] New sequence commences... 15:12:20: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000 15:12:20: INFO: [???] STREAM e0 completed @ frame 14. 15:12:20: INFO: [???] Multiplex completion at SCR=4096. 15:12:20: INFO: [???] Video e0: buf= 49929 frame=000014 sector=00000026 15:12:20: INFO: [???] VIDEO_STATISTICS: e0 15:12:20: INFO: [???] Video Stream length: 50472 bytes 15:12:20: INFO: [???] Sequence headers: 2 15:12:20: INFO: [???] Sequence ends : 0 15:12:20: INFO: [???] No. Pictures : 15 15:12:20: INFO: [???] No. Groups : 2 15:12:20: INFO: [???] No. I Frames : 2 avg. size 16289 bytes 15:12:20: INFO: [???] No. P Frames : 14 avg. size 1239 bytes 15:12:20: INFO: [???] No. B Frames : 0 avg. size 0 bytes 15:12:20: INFO: [???] Average bit-rate : 756400 bits/sec 15:12:20: INFO: [???] Peak bit-rate : 534400 bits/sec 15:12:20: INFO: [???] BUFFERING stream too short for useful statistics 15:12:20: INFO: [???] MUX STATUS: no under-runs detected. create sub file....done. running menu muxer....15:12:21: MUXRATE =4400 15:12:21: after read_bmp(): xd=720 yd=480 x0=0 y0=0 15:12:21: Found EOF in .sub file. 15:12:21: warning, sub on line 0 starts before 4s, (some players won't show it) 15:12:21: subtitle duration: -1 15:12:21: ***************** HERE WE GO EVE.ODD ******************* 15:12:21: MenuType: EVEN 15:12:21: subtitle_packet_size: 1682 15:12:21: subtitle_packet_size & 1: 0 15:12:21: subtitle_packet_size mod 2: 0 15:12:21: MenuType=="" 15:12:21: MenuType=="EVEN" 15:12:21: final subtitle_packet_size: 1682 15:12:21: max_sub_size=1682 15:12:21: subtitle inserted at: 0.176400 sd=0 15:12:21: max_sub_size=1682 15:12:21: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18 done. create PS sub for file....done. running menu muxer....15:12:21: MUXRATE =4400 15:12:21: after read_bmp(): xd=720 yd=480 x0=0 y0=0 15:12:21: Found EOF in .sub file. 15:12:21: warning, sub on line 0 starts before 4s, (some players won't show it) 15:12:21: subtitle duration: -1 15:12:21: ***************** HERE WE GO EVE.ODD ******************* 15:12:21: MenuType: EVEN 15:12:21: subtitle_packet_size: 1986 15:12:21: subtitle_packet_size & 1: 0 15:12:21: subtitle_packet_size mod 2: 0 15:12:21: MenuType=="" 15:12:21: MenuType=="EVEN" 15:12:21: final subtitle_packet_size: 1986 15:12:21: max_sub_size=1986 15:12:21: subtitle inserted at: 0.176400 sd=0 15:12:21: max_sub_size=1986 15:12:21: 1 subtitles added, 0 subtitles skipped, stream: 33, offset: 0.18 done. 15:12:21: Encoding menu...Done. 15:12:21: SVCD2DVD: DVDfolders Generating DVD folders please wait.... 15:12:21: -->: DVDFolders creating table of contents 15:12:21: scanning F:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO 15:12:21: -->: Creating menu for TOC 15:12:21: DVD Folders: Processing C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\menu.mpg... 15:12:21: 15:12:21: 15:12:21: Finalising DVD...Done 15:12:21: Done: Authoring DVD Folders
Code:******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** SVCD2DVD ***************************** Name: SVCD2DVD 2.5 Title: 2.5 Version: 2.5.5030.0 Executable: C:\Video\SVCD2DVD\SVCD2DVD.exe Executable size: 2.58 MB Executable size in bytes: 2711635 Executable CreationTime: 28/01/2009 15:57:36 Executable LastWriteTime: 23/08/2009 15:24:09 Executable LastAccessTime: 23/08/2009 15:24:09 ************************* Operating System ************************* Operating System: Microsoft Windows 7 Ultimate Service Pack: Version : 6.1.7100 Windows Directory : C:\Windows OSLanguage: 1033 CodeSet: 1252 CountryCode: 44 Local: 0809 Total Physical Memory: 3.99 GB Free Physical Memory: 2.48 GB Total Virtual Memory: 7.99 GB Free Virtual Memory: 6.20 GB ***************************** Computer ***************************** Computer Manufacturer Name: HP-Pavilion Computer Model: KZ756AA-ABU m9351.uk System Type: x64-based PC Computer Name: REDACTED DomainRole: x2c3419cdc9b8e007 Number Of Processors: 1 User Name: REDACTED\REDACTED ***************************** Processor **************************** Manufacturer: GenuineIntel Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Description: Intel64 Family 6 Model 15 Stepping 11 CPU Speed: 2.4GHz CPU FSB: 1.066GHz L2 Cache Size: 8.00 KB 15:08:50: Logical CPUs: 4 ***************************** Time Zone **************************** Time Zone: (UTC) Dublin, Edinburgh, Lisbon, London ****************************** VIDEO ******************************* Name: NVIDIA GeForce 9600 GSO 512 Processor: GeForce 9600 GSO 512 Mode: 1440 x 900 x 4294967296 colors Video Ram: 1.00 GB Status: OK ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 39.9 GB FreeSpace: 7.08 GB DeviceID: D: FileSystem: NTFS Size: 425 GB FreeSpace: 132 GB DeviceID: E: FileSystem: NTFS Size: 312 GB FreeSpace: 29.8 GB DeviceID: F: FileSystem: NTFS Size: 153 GB FreeSpace: 52.5 GB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ************************* ProjectMetaData ************************** <?xml version="1.0" encoding="utf-8"?> <SVCD2DVD DateTime="03/10/2009 15:08:50" Filename="NONE"> <AssetSet> <Asset ID="3921fbae-49e9-4d7b-af3f-040a8005a408" Path="F:\" Filename="5x03 - The Plain In The Prodigy_S2D.mpg" /> </AssetSet> <DVDStructure> <TitleSet Name="5x03 - The Plain In The Prodigy" PostCmd="" MenuButtonType="0"> <MenuButton X1="213" Y1="247" X2="747" Y2="293" FontFamily="Tahoma" FontSize="24" FontStyle="3">5x03 - The Plain In The Prodigy</MenuButton> <Title Name="5x03 - The Plain In The Prodigy_S2D.mpg" AssetID="3921fbae-49e9-4d7b-af3f-040a8005a408" MplexOffset="0" /> </TitleSet> <DVDMenu Normal="-4144960" Highlight="-1" Active="-16777216" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="F:\Projects\Metallic.bmp" AudioPath="" /> </DVDStructure> <Settings> <General InitialAssetFolder="F:\" InitialDVDFolder="F:\" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="F:\Projects" InitialMenuBackgroundFolder="F:\Projects" DeleteS2DFiles="False" UseDVDShrink="False" /> <Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="F:\Projects\Metallic.bmp" TVStandard="NTSC" FontFamily="Tahoma" FontSize="15.75" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="True" MenuAspectRatio="AR_16_9" /> <Process AudioEncoding="ac3" Chapters="Every 5 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" /> <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /> <Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /> </Settings> </SVCD2DVD> ************************* ProjectMetaData ************************** Processing assets for DVD creation =================== AV Details =================== File Size: 2.17 GB file=F:\\5x03 - The Plain In The Prodigy_S2D.mpg FormatName=mpeg Num_Frames=62000 DurationInSecs=2586 Duration=00:43:05.9 VideoCodec=mpeg2video VideoFFSTNum=0 Width=720 Height=480 Standard=NTSC BitRate=7240 AudioStreamCount=1 Audio1FFSTNum=1 Audio1StreamID=[0x80] Audio1SampleRate=48000 Audio1Codec=ac3 Audio1BitRate=448 Audio1Channels=6 =================== AV Details =================== 15:08:50: Leaving 5x03 - The Plain In The Prodigy_S2D.mpg alone. File has Nav Packs 15:08:52: Done: Processing assets for DVD creation Authoring DVD Folders 15:08:52: Creating TitleSet # 1 15:08:52: SVCD2DVD: DVDfolders Generating DVD folders please wait.... 15:08:52: -->: DVDFolders creating VTS 15:08:52: -->: VTS 01 15:08:52: DVD Folders: Processing C:\Video\SVCD2DVD\dummymenuNTSC.mpg... 15:08:52: DVD Folders: Processing F:\5x03 - The Plain In The Prodigy_S2D.mpg... 15:10:13: 15:10:13: 15:10:13: 15:10:13: Finalising DVD... 15:10:13: Encoding menu... ---------------------------- ENCODING MENU ---------------------------- TV Standard: NTSC Aspect Ratio: 16:9 Image size: 960x540 Resize size: 720x480 ---------------------------- ENCODING MENU ---------------------------- [] 15:10:13: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al. [] 15:10:13: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices [] 15:10:13: libavutil 49.12. 0 / 49.12. 0 [] 15:10:13: libavcodec 52. 6. 0 / 52. 6. 0 [] 15:10:13: libavformat 52.23. 1 / 52.23. 1 [] 15:10:13: libavdevice 52. 1. 0 / 52. 1. 0 [] 15:10:13: libswscale 0. 6. 1 / 0. 6. 1 [] 15:10:13: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502 [] 15:10:13: Input #0, image2, from 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\background1.jpg': [] 15:10:13: Duration: 00:00:00.04, start: 0.000000, bitrate: N/A [] 15:10:13: Stream #0.0: Video: mjpeg, yuvj420p, 720x480 [PAR 96:96 DAR 3:2], 25.00 tb(r) [] 15:10:13: Output #0, rawvideo, to 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\backgroundES.mpv': [] 15:10:13: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=2-31, 6000 kb/s, 29.97 tb(c) [] 15:10:13: Stream mapping: [] 15:10:13: Stream #0.0 -> #0.0 [] 15:10:13: Press [q] to stop encoding [] 15:10:13: video:49kB audio:0kB global headers:0kB muxing overhead 0.000000% 15:10:13: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $) 15:10:13: INFO: [???] File C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv looks like an MPEG Video stream. 15:10:13: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options! 15:10:13: INFO: [???] Found 0 audio streams and 1 video streams 15:10:13: INFO: [???] Selecting dvdauthor DVD output profile 15:10:13: INFO: [???] Multiplexing video program stream! 15:10:13: INFO: [???] Scanning for header info: Video stream e0 (C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv) 15:10:13: INFO: [???] VIDEO STREAM: e0 15:10:13: INFO: [???] Frame width : 720 15:10:13: INFO: [???] Frame height : 480 15:10:13: INFO: [???] Aspect ratio : 16:9 display 15:10:13: INFO: [???] Picture rate : 29.970 frames/sec 15:10:13: INFO: [???] Bit rate : variable 15:10:13: INFO: [???] Vbv buffer size : 212992 bytes 15:10:13: INFO: [???] CSPF : 0 15:10:13: INFO: [???] SYSTEMS/PROGRAM stream: 15:10:13: INFO: [???] rough-guess multiplexed stream data rate : 0001248 15:10:13: INFO: [???] target data-rate specified : 10080000 15:10:13: INFO: [???] Setting specified specified data rate: 10080000 15:10:13: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 15876 15:10:13: INFO: [???] New sequence commences... 15:10:13: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000 15:10:13: INFO: [???] STREAM e0 completed @ frame 14. 15:10:13: INFO: [???] Multiplex completion at SCR=4096. 15:10:13: INFO: [???] Video e0: buf= 49672 frame=000014 sector=00000026 15:10:13: INFO: [???] VIDEO_STATISTICS: e0 15:10:13: INFO: [???] Video Stream length: 50256 bytes 15:10:13: INFO: [???] Sequence headers: 2 15:10:13: INFO: [???] Sequence ends : 0 15:10:13: INFO: [???] No. Pictures : 15 15:10:13: INFO: [???] No. Groups : 2 15:10:13: INFO: [???] No. I Frames : 2 avg. size 16215 bytes 15:10:13: INFO: [???] No. P Frames : 14 avg. size 1231 bytes 15:10:13: INFO: [???] No. B Frames : 0 avg. size 0 bytes 15:10:13: INFO: [???] Average bit-rate : 752800 bits/sec 15:10:13: INFO: [???] Peak bit-rate : 531600 bits/sec 15:10:13: INFO: [???] BUFFERING stream too short for useful statistics 15:10:13: INFO: [???] MUX STATUS: no under-runs detected. create sub file....done. running menu muxer....15:10:14: MUXRATE =4400 15:10:14: after read_bmp(): xd=720 yd=480 x0=0 y0=0 15:10:14: Found EOF in .sub file. 15:10:14: warning, sub on line 0 starts before 4s, (some players won't show it) 15:10:14: subtitle duration: -1 15:10:14: ***************** HERE WE GO EVE.ODD ******************* 15:10:14: MenuType: EVEN 15:10:14: subtitle_packet_size: 1705 15:10:14: subtitle_packet_size & 1: 1 15:10:14: subtitle_packet_size mod 2: 1 15:10:14: MenuType=="" 15:10:14: MenuType=="EVEN" 15:10:14: WAS ODD 15:10:14: subtitle_packet_size++ 15:10:14: final subtitle_packet_size: 1706 15:10:14: max_sub_size=1706 15:10:14: subtitle inserted at: 0.176400 sd=0 15:10:14: max_sub_size=1706 15:10:14: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18 done. create PS sub for file....done. running menu muxer....15:10:14: MUXRATE =4400 15:10:14: after read_bmp(): xd=720 yd=480 x0=0 y0=0 15:10:14: Found EOF in .sub file. 15:10:14: warning, sub on line 0 starts before 4s, (some players won't show it) 15:10:14: subtitle duration: -1 15:10:14: ***************** HERE WE GO EVE.ODD ******************* 15:10:14: MenuType: EVEN 15:10:14: subtitle_packet_size: 2010 15:10:14: subtitle_packet_size & 1: 0 15:10:14: subtitle_packet_size mod 2: 0 15:10:14: MenuType=="" 15:10:14: MenuType=="EVEN" 15:10:14: final subtitle_packet_size: 2010 15:10:14: max_sub_size=2010 15:10:14: subtitle inserted at: 0.176400 sd=0 15:10:14: max_sub_size=2010 15:10:14: 1 subtitles added, 0 subtitles skipped, stream: 33, offset: 0.18 done. 15:10:14: Encoding menu...Done. 15:10:14: SVCD2DVD: DVDfolders Generating DVD folders please wait.... 15:10:14: -->: DVDFolders creating table of contents 15:10:14: scanning F:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO 15:10:14: -->: Creating menu for TOC 15:10:14: DVD Folders: Processing C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\menu.mpg... 15:10:14: 15:10:14: ERR: Error opening F:\SVCD2DVD_OUTPUT\VIDEO_TS/VIDEO_TS.VOB_0.VOB: No such file or directory
Results 1 to 1 of 1
SVCD2DVD menu problem
By Orakal in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 2nd Feb 2007, 08:42 -
SVCD2DVD Menu Problem
By Looney 1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 31st Jan 2007, 16:39 -
menu problem with RC8 svcd2dvd
By gmkilp in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 12th Apr 2005, 10:56 -
Help! Strange problem / help request burning DVD menu
By web_woman in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2004, 22:10 -
VCDeasy - SVCD menu - strange problem... please help.
By Comfy in forum Authoring (VCD/SVCD)Replies: 0Last Post: 26th Nov 2002, 08:09
