Hi all,
I tried converting a *.mp4 file to two-VCD. However the end result is "Failed".
I tried pasting the info to a text file but it is 8.6MB. THe maximum limit is 6MB. Which part of the info do you need to see to know what went wrong?
errorinfo.rtf
Thread: Error creating VCD
Cut out the repetitive parts. It's the error message(s) near the end that's interesting.
Does this contain sufficient info?
(Super) VideoCD xml description created successfully as `/Users/User/Desktop/Horton-1.mpg.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN:
++ WARN: generated image (352607 sectors [78:21.32]) may not fit on 74min CDRs (333000 sectors)
(Super) VideoCD xml description created successfully as `/Users/User/Desktop/Horton-2.mpg.xml'
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `/Users/User/Desktop/Horton:.xml'
**ERROR: could not stat() file `/Users/User/Desktop/Horton:': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `/Users/User/Desktop/Horton_Hears_A_Who:.xml'
**ERROR: could not stat() file `/Users/User/Desktop/Horton_Hears_A_Who:': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Audio.xml'
**ERROR: could not stat() file `Audio': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `2.xml'
**ERROR: could not stat() file `2': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `ch.xml'
**ERROR: could not stat() file `ch': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Horton.xml'
**ERROR: could not stat() file `Horton': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Hears.xml'
**ERROR: could not stat() file `Hears': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `A.xml'
**ERROR: could not stat() file `A': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Who!.jpg.xml'
**ERROR: could not stat() file `Who!.jpg': No such file or directory
++ WARN:
++ WARN:
++ WARN:
++ WARN:
++ WARN:
++ WARN:
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Who!.mp4.ff.xml'
**ERROR: could not stat() file `Who!.mp4.ff': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Horton_Hears_A_Who.mp4.xml'
**ERROR: could not stat() file `Horton_Hears_A_Who.mp4': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Kingdom.xml'
**ERROR: could not stat() file `Kingdom': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `RG.xml'
**ERROR: could not stat() file `RG': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Please.xml'
**ERROR: could not stat() file `Please': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `read.nfo.xml'
**ERROR: could not stat() file `read.nfo': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Sample.xml'
**ERROR: could not stat() file `Sample': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Subs.xml'
**ERROR: could not stat() file `Subs': No such file or directory
++ WARN:
++ WARN:
Encoding completed on Sun Oct 4 22:36:30 MYT 2009
This is on a Mac and it looks like a path problem. Unfortunately for you, I don't do any video work on Macs so I can't help you. But it's more of a Mac problem than an ffmpegX problem. If you don't get any help in a day or two, ask a moderator such as Baldrick to move your post to our Mac forum.
The log shows it is trying to process much more files than it needs to. Not sure why.
Try doing the process in two steps:
(1) Convert to VCD, disable authoring, disable file splitting (in Options). Check playback of the output .mpg file.
(2) Author just the .mpg file as VCD, using the Author tool (in Tools), enable file splitting (Auto split).
Much more control, and if something goes wrong, it will be easier to determine what and where in the process.
"ERR: MuxMan error!" while Creating DVD in GfD
By michcio in forum Authoring (DVD)Replies: 2Last Post: 6th Dec 2008, 18:05 -
error creating an img file
By theft in forum ffmpegX general discussionReplies: 8Last Post: 2nd Nov 2007, 15:05 -
Error message when creating titlesets
By simdart in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Sep 2007, 08:35 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05 -
Creating Title Set Error
By illpeeonu in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 29th May 2007, 04:04
