VideoHelp.com Forum
    I have a TRV-900 I want to retire and need a good way to archive the MiniDV tapes without quality loss. Can I do this with iMovie 9 on my iMac? Or will it convert it to a lower quality?
    I will probably get Premiere Pro CS4 on my Windows machine but I was hoping to use iMovie or another quick and reliable method to save to a USB Disk.
    Thanks in advance!
  2. the only format that can be considered lossless is to keep it in DVavi, the same format as on the tape. it's 13GB/hr so plan accordingly.
  3. BuskerAlley.com zoobie's Avatar
    and keep your tapes
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  4. You can also zip or rar you DV files, you can reduce significantly their size (although compression is rather slow). You can gain up to 100 MB on a 800 MB DV avi file.
    Thanks, that helps.
    I will obviously keep the tapes. I'll try doing a straight copy of the avi files, I am too impatient to zip them!
    I ran into a problem - anyone know how I can mount the camera (firewire only) on my iMac?
    I can see it and control it in iMovie, but if I import from there it will be converted to the iMovie format, right? I was hoping to just do a straight copy/archive as suggested.
  7. BuskerAlley.com zoobie's Avatar
    glad it's obvious to you
    too bad it isn't to the others
    dunno about your imac
    maybe this bump will help
  1. Best settings and format for ARCHIVE footage ?
    By Bansaw in forum Video Conversion
    Last Post: 28th Apr 2012, 09:55
  2. Archive MiniDV
    By bdr13278 in forum Video Conversion
    Last Post: 6th Feb 2010, 09:29
  3. MiniDV Edit and Archive
    By quxote in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Jan 2009, 12:22
  4. Archive my camcorder footage
    By jpc82 in forum Video Conversion
    Last Post: 5th May 2007, 05:23
