Hey,
I've got a Humax PVR 1000c with the swedish carrier ComHem and I'm trying to hook it up to my hdmi splitter in order to get channels in multiple rooms... but, it won't work! Splitting an HDMI from my PC works fine with the same setup and equiptment, but not from the HUMAX... So this is probably a trick from the service provider Comhem who wants me to buy multiple cards... bastards!
So basically, the question is if I somehow can hack the Humax PVR 1000c so it won't screw up the signal and I can enjoy my late night porn in every room of the house??
Cheers,
P
I would search and ask in http://www.minhembio.com/forum/index...owtopic=215864
done that, but i'm not getting my hopes up, I think this sort of stuff isn't the specialty of people who frequent that forum... anybody got any suggesttions?
p.s. I've contacted both Comhem and Humax and they won't help!
HDCP doesn't allow HMDI splitting. There are HDCP removal devices but they aren't cheap:
http://www.curtpalme.com/MUX-HD.shtm
r u sure, because the splitter is HDCP compliant... wouldn't that mean that HDCP shouldn't be a problem?
here, check it out: http://www.monoprice.com/products/pr...1&format=6#faq
I believe "HDCP compliant" means: If the HDCP stream says you're allowed to split it, you can. If it says you aren't allowed to split it, you can't.
Humax .ts conversion ... ?????
By Stonechatz in forum DVB / HDTVReplies: 6Last Post: 24th Feb 2012, 02:24 -
Element HDMI DVD Player EDHFT12 - Region Hack?
By haitek in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Oct 2011, 08:50 -
Splitting DVI and HDMI signals. Veterans please check my setup
By anubis13 in forum ComputerReplies: 9Last Post: 21st Jan 2010, 16:14 -
HDMI Workaround or hack
By Scooter_NJ in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Mar 2008, 21:11 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
