VideoHelp.com Forum
Results 1 to 14 of 14
    Hi, I'm having a problem with my just purchased copy of VOB2MPG-Pro. The message I get is finished processing 0 vobsets. This happens for every set of vob files I try to merge.
    Just to see what would happen, I tried IFO mode. In that mode the preview does not work, I get no video although I get a brief snippet of sound before it stops. When I click extract I immediately get the message finished processing.
    I found an old version ChrissyBoy had provided someone in a forum post as a fix. (A level of version 2.4 dated Thursday, July 20, 2006, 8:35:44 AM with size of 2,010,624 bytes) This version combined the vobs quickly. The resulting mpg plays fine with Windows Media Player. The only problem I've noticed is the timestamp is off when played through my UPnP AV server and player. I was actually hoping to fix the timestamp issue by purchasing the pro version.
    I'm running Windows XP Home, service pack 3 and have .NET framework 2.0 service pack 2 installed.
    I've included one of the logs below. Pretty short, but it's the whole thing.
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title: PRO
    Version: 3.0.0100
    Executable: C:\VOB2MPG PRO\VOB2MPG.exe
    Executable size: 855 KB
    Executable size in bytes: 875603
    Executable CreationTime: 9/26/2009 2:58:44 AM
    Executable LastWriteTime: 10/3/2009 2:27:59 AM
    Executable LastAccessTime: 10/3/2009 3:12:28 AM
    ****************************** Drives *******************************
    Thanks for any assistance.
  2. Member ChrissyBoy's Avatar
    Do any of the other logs have more info in them please?
    No, except for the times, they are all the same.
  4. Member ChrissyBoy's Avatar
    ok
    What is the path of the source please?
    The source path is: E:\DVDs\MainMovie\MOVIE1\VIDEO_TS
    The destination path is : C:\Documents and Settings\All Users\Documents\My Videos
    I have also tried with the source as C:\Media\VIDEO_TS
    I'm suspicious of ffmpeg since the preview does not work. But that probably does not have anything to do with the log stopping when it is apparently discovering the drives.
    Jay
  6. Member ChrissyBoy's Avatar
    Ok The program uses WMI to deduce stuff about the drives.... Have you disabled the service?
    Hi, just downloaded VOB2MPG (freeware) today to see it it will assist with a large VHS project. If so, I'll go PRO. But.., I am having the same problem jay782: that is I select VOBSET, identified the folder (it exists on both my desktop and a DVD: tried both locations), get the "Green Arrow" in the Start Extraction icon, click it, and get "Finished Processing 0 VOB sets; duration 00:00:00. The log shows only:
    Title:
    Version: 3.0.0060
    Executable: C:\Program Files (x86)\BadgerIT\VOB2MPG v3\%APPNAME%.EXE
    Executable size: 808 KB
    Executable size in bytes: 827904
    Executable CreationTime: 1/1/2000 12:00:00 AM
    Executable LastWriteTime: 1/1/2000 12:00:00 AM
    Executable LastAccessTime: 1/1/2000 12:00:00 AM
    Source data path is G:\Video_TS
    (also tried conversion from C:\users\{name}\desktop\video_ts which did not work either)
    Note: G: is an Optiarc DVD RW AD7590S ATA Device
    Output location is: C:\Users\JamesL\Desktop\VIDEO_TS (program generated)
    As far as I can tell, I followed the help files to the letter. What now?
    When we remember we are all mad, the mysteries disappear and life stands explained: Mark Twain
    I think you've nailed it in my case. Although the WMI service is running it is apparently not working correctly. When I use the System Information tool I receive a message Cannot access the Windows Management Instrumentation software. Windows Management files may be moved or missing.
    I'll go on a quest to fix that and let you know the results.
    Thanks for your assistance.
  9. Member ChrissyBoy's Avatar
    Cool - keep us posted!
  10. Member ChrissyBoy's Avatar
    Title:
    Version: 3.0.0060
    Perhaps the same issue? Have you tried the System Info Tool in Accesories->System Tools to confirm?
    After searching and trying a couple of different methods to repair WMI, this page provided the solution that worked for me. You have to register to access the full article:
    http://searchwindowsserver.techtarge...3_mem1,00.html
    Read all the details, but this is the guts of it:
    1. At the command line, type net stop winmgmt. You may get a warning that other services need to be stopped as well; type Y and continue.
    2. Open Explorer and go to the folder called %SystemRoot%\System32\WBEM\Repository.
    3. Delete that folder and everything in it.
    4. Reboot the system normally.
    5. On the next login, open a command prompt and type the following commands in this order:
    winmgmt /clearadap
    winmgmt /kill
    winmgmt /unregserver
    winmgmt /regserver
    winmgmt /resyncperf
    Now WMI works and I am able to use vobset mode to merge vob files, with one exception. I still get the 0 vobsets message if the destination is in the path of the source. This didn't work:
    Source:E:\DVDs\MainMovie\MOVIE1\VIDEO_TS
    Destination:E:\DVDs\MainMovie\MOVIE1
    But when I send the file someplace else, like my C drive it works fine. I can live with that.
    I tried jay782's solution: it's a no-go for Vista. Vista (x64 that is) winmgmt does not support the /clearadap, /kill, /unreg..., /regserver paramaters. It does support /resyncperf.
    Vista winmgmt switches are almost 100% different from the jay782 referenced article. They are [/backup <filename>] [/restore <filename> <flag>][/resyncperf] [/standalonehost [<level>]] [/sharedhost] [/verifyrepository [<path>]] [/salvagerepository] [/resetrepository] of which the text of "salvagerepository" seems to imply it does the work of the article's 5 commands.
    All that aside, I 'salvaged' my repository to be told it was consistent (I did blow it away and reboot as advised), after which I reran VOB2MPG and got the same results I posted earlier. So... rather than fight with Vista, I'll try this on an XP machine I have access to. Has anyone successfully used VOB2MPG in any Vista x64 (not 32 bit) version?
  13. Member ChrissyBoy's Avatar
    Can you try installing in a folder other than "program files"?
  14. Member ChrissyBoy's Avatar
    winmgmt /clearadap
    winmgmt /kill
    winmgmt /regserver
    winmgmt /resyncperf
    Nice one!
  1. VOB2MPG Batch Processing
    By jonj1611 in forum SVCD2DVD & VOB2MPG
    Last Post: 26th Aug 2011, 13:35
  2. VOB2MPG PRO command line not processing in 64bit Windows 7
    By BJTHEDJ in forum SVCD2DVD & VOB2MPG
    Last Post: 6th Dec 2010, 15:53
  3. Unable to install VOB2MPG or VOB2MPG PRO
    By tooc in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Mar 2010, 00:53
  4. finished processing with no files
    By l4l4u in forum SVCD2DVD & VOB2MPG
    Last Post: 15th Oct 2009, 02:35
  5. VOB2MPG 2.5 Finished processing 0 vobsets. Duration 00:00:00
    By d4d9d4 in forum SVCD2DVD & VOB2MPG
    Last Post: 24th Jul 2008, 17:31
