I'm trying to get a File that is playable on my Ipod Touch, Zune and Somy PSP.
Both the Ipod and the Zune are fairly compatible and can play their files. he Hitch is the PSP
I have to keep the file at either 480x Under 272, or 720x480 for the PSP, plus there arre other restrictions as well
Anyone have any advice for getting a encode that will work on all three devices?
Thread: Encoding for Multiple Devices
Option 1) Use MPEG4 SP (Divx) with 480x272 resolution.
Option 2) Restrict H264 profile (for example, no CABAC).
PSP cannot Play Divx at any resolution
Sure it can.Originally Posted by Scarpad
Divx is just the video codec used to encode a video that satisfies MPEG4 SP and packaged in MP4 container.
What converter are you using?
using multiple audio devices in Windows 7
By Ennio in forum Media Center PC / MediaCentersReplies: 0Last Post: 10th Apr 2012, 16:48 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video StreamingReplies: 1Last Post: 31st Jan 2010, 15:04 -
3GP_Converter (For Apple Devices) Updated: Quad Core Support + CRF Encoding
By GMaq in forum Portable VideoReplies: 1Last Post: 20th Sep 2008, 08:52 -
XP Home -- configuring I/O and USB Devices with multiple user accounts ?
By vhelp in forum ComputerReplies: 1Last Post: 24th Jun 2007, 12:24
Statistics
Newest guides
Latest tool updates
New media comments
