I'm looking to get a 4 port HDMI switch.
It will connect to a generation 2 Plasma via HDMI to DVI
Other than looking at Newegg reviews, does anyone have suggestions on brands to get or avoid?
BTW, so far the only device that will not work HDMI to DVI is a Toshiba HD-A30 I picked up for $20. Plays fine via component, just wont negotiate a HDMI connection
Thread: HDMI switches
I've used three different ones from MonoPrice and no problems with any. They use HDMI from my video cards that have a DVI-HDMI adapter and feed my projector. Work fine for BD discs or MKV. http://www.monoprice.com/products/su...09&cp_id=10110
Well, I did some reading at monoprice...BTW thanks for that as I've never been there before.
Looks like the 5 port is better than the 4 port.
Since reading all the reviews and doing some research, I may end up getting 5 port and the Fury2
I'm looking at the handshack problem I had with the Toshiba HD player
I know I have no problems with HD via component
MonoPrice is a decent company. Never had problems with them. The HDMI switches I got from them work fine with my setup. My last purchase was for a HDMI splitter so I could use my HDMI output for my projector and my HDMI enabled monitor. Works great. And their cables are a bargain.
HDMI handshake is a PITA. Most of my components work fine. But if your video card is off on some weird setting, HDMI may not want to work. It also adds some seconds to any HDMI playback as it negotiates. PowerDVD took forever to display. Total Media Theater is faster for startup, but not a whole lot.
Too bad my 4 year old 42" plasma still has a great picture. I just can't convience myself to replace a good working TV with a newer just because it's a 2nd generation and has problems with HDCP.
The Fury2 would solve that problem
Again, thanks for informing me about monoprice. Great site. Then reading that site I found BlueJeans, another great site
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum CapturingReplies: 0Last Post: 23rd Sep 2009, 16:51 -
HDMI Wall Plate>>Quality?----HDMI over Cat5E/Cat6????
By cpeters12 in forum DVB / HDTVReplies: 4Last Post: 8th Aug 2009, 21:46 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / HDTVReplies: 1Last Post: 25th Apr 2009, 09:40 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 12:35 -
connecting the hdmi port of toshiba hd dvd A2 to hdmi switcher, i need info
By dxgmde in forum Newbie / General discussionsReplies: 0Last Post: 13th Mar 2007, 07:21
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksVSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
