VideoHelp.com Forum
Results 1 to 9 of 9
    Im using MakeMKV to convert blu-ray movies to MKV will i lose any quality doing so?
    MakeMKV says it does not convert audio or video, just takes the streams as-is. You will get very big files though.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Nope, it doesn't convert. But it doesn't work with ALL blu-rays.
    You can also use Clown_BD and ToNMT.
    Thanks for that info. What exactly does MakeMKV do? If it's not converting the video is it just pulling it off the disc into a .mkv?
    I don't really care about the size. What simple to use software can take a single file from a blu-ray movie and convert it to mkv?
  5. Mod Neophyte Super Moderator redwudz's Avatar
    It repackages the contents of the decrypted BD into a MKV container.
  6. Banned
    ... for the purpose of burning it onto DVD-R or having a copy on a HDD etc.
    You get exact same quality as it was on BD, nothing better or worse, the advantage is in the freedom of not being restricted and having ability to do whatever you want to do whenever you want to do with it
    It may seem like not much, but if you think of it it'll become apparent that IT IS SO MUCH!
    Except that taking a full BD disc and simply repackaging it into an MKV file will likely mean using 4- 5 single layer DVDs or 2 - 3 DL DVDs to hold the movie.
    Looks like you where right MakeMKV does not work on some blu-rays.
    So how can i get blu-rays to mkv WITHOUT converting the video? Most of the how to's convert the video.
  9. Banned
    Yes if you use DVD-Rs. The point is the *freedom* of doing it, not where you may want to store or burn it. You can use SD cards or BD-Rs if you want
    BTW - I love your new "pigasus" avatar!
  1. Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
    By brad350 in forum Newbie / General discussions
    Last Post: 21st Apr 2012, 04:15
  2. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  3. converting blu-ray to mkv without losing quality
    By Arkadietz in forum Blu-ray Ripping
    Last Post: 3rd Oct 2011, 17:31
  4. Blu ray to .mkv. looking for top quality
    By llmercll in forum Blu-ray Ripping
    Last Post: 2nd Jan 2009, 08:47
  5. converting blu-ray to mkv without losing quality using SUPER
    By nymphadora in forum Blu-ray Ripping
    Last Post: 24th Jul 2008, 10:36
