VideoHelp.com Forum
Thread: Podcasting Woes
    So I have started a podcast and I have really crappy equipment. I am using a webcam and we are sitting around a table. Also, using audacity, skype, pamela and adobe premiere pro CS4.
    We are having an issue with the audio cracking when people laugh. I think maybe its just this webcam is being overloaded. Anybody have any advice on the types of equipment I can get at an affordable price to boost my podcast sound quality? I think we will need audio equipment that supports 3-4 people into the same computer. Audio splitter? Mixer? Any advice please. Thanks!
    Get the best quality mics you can afford. A small mixer would also be good. You also need a compressor on the input signal. This will help stop you clipping, and help normalise the volume as you record.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Thanks but can you be a little more specific? I'm not really sure what mics are good or the specifics of a small mixer or compressor...
    Some reading matter for you
    http://www.peachpit.com/articles/art...13667&seqNum=3
    http://hivelogic.com/articles/podcas...uipment-guide/
    http://www.podcastblaster.com/podcasting-equipment.html
    http://www.digitalpodcast.com/podcastingequipment/
    As your profile is full of gibberish I don't know if you are working on a Mac or Windows platform (not particularly helpful - I suggest you fix it soon). As well as Audacity I would suggest you look at Reaper, which is a multi-track recorder with a lot of features.
    You might also google for Podcasting Forums and find one that addresses podcasting specifically. I have yet to produce one, but I listen to a lot of them, and the quality and production differences range wildly between something that sounds like someone in their den, to studio quality. I do know that some of my favourites that do have good production values are recorded in a lounge room, so a studio is not a necessity.
  1. Podcasting using 3 wireless lav mics?
    By chrisshawyeah in forum Audio
    Last Post: 20th Dec 2011, 01:17
  2. Live Podcasting Question
    By hellfire45 in forum Audio
    Last Post: 14th Jan 2011, 17:35
  3. VC-1 Encoding woes...
    By madmillington in forum Video Conversion
    Last Post: 16th Sep 2010, 16:14
  4. Resolution woes
    By newsphotog in forum Newbie / General discussions
    Last Post: 29th Sep 2009, 13:06
  5. Nero woes
    By turk690 in forum Editing
    Last Post: 13th Sep 2009, 18:27
