  1. Member AlanHK's Avatar
    I had my Windows codecs scrambled by someone installing a random video app.
    I got rid of it but was left with some problems, specifically with AviSource in Avisynth.
    If I now use AviSource() to open an AVI file using MP3 audio, it comes up with an error:
    "The requested conversion is not possible".
    Previously these worked fine.
    I installed ffdshow and that allows me to play just about anything, and is invoked by DirectShowSource(), but AviSource can't use these and still gives the same error.
    What do I need to install/enable so AviSource can handle MP3?
    This is in Win2k, but most things work the same as XP.
  2. did you try re-installing a mp3 codec?
  3. Member Soopafresh's Avatar
    I think it's Lame ACM that you're looking for
    "Quality is cool, but don't forget... Content is King!"
    Maybe re-registering quartz.dll? Or l3codeca.acm, l3codecp.acm, or l3codecx.ax?
  5. Member AlanHK's Avatar
    l3codeca.acm was in the system32 folder and was unregistered
    in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32.
    -- Looking inside the file it's apparently the Fraunhofer MP3 decoder.
    (lameACM.acm was already registered though.)
    So I ran:
    regsvr32.exe "D:\WinNT\system32\l3codeca.acm"
    And now it's registered and AviSource works.
    Thanks!
    (I put a similar post on Doom9 a few days ago, as that's the fount of all Avisynth knowledge. 60+ views, not one single reply.)
    LameACM is only an encoder.
  1. Difference between DirectShowSource & aviSource?
    By romi7519 in forum Newbie / General discussions
    Last Post: 21st May 2007, 13:18
  2. Avisource: Could not decompress frame 0 error
    By peter p in forum SVCD2DVD & VOB2MPG
    Last Post: 10th Jul 2006, 15:09
  3. Replies: 3
    Last Post: 13th Dec 2005, 23:25
  4. MP3 codec?
    By Sasarchiver in forum Video Conversion
    Last Post: 28th Feb 2005, 09:18
  5. Where can I download the Huffy codec? and an MP3 Codec?
    By CaptainProton in forum Capturing
    Last Post: 26th Apr 2002, 23:56
About   Advertise   Forum   RSS Feeds   Statistics   Tools
