    I've tried (and tried again) but have not been able to get the DVD Preview working on XP SP3. The error message is
    Could not get interfaces
    No such interface supported
    I've just purchased the Pro version, but unfortunately still get the same message.
    I can view the video in both WMP11 and VLC. And have installed both AC3Filter and ffdshow (and enabled the MPEG2 codec) but still no joy.
    Can anyone please help?
  2. Member ChrissyBoy's Avatar
    If you launch the ffdshow video decoder config app... What do you have here:
    Thanks for your quick reply. Please see screen grab attached.
    I also tried changing 'Multiple ffdshow instances' to "no limitations", which unfortunately didn't help.
    Any ideas?
  4. Member ChrissyBoy's Avatar
    I would try wacking the merit to the max.
    Then when you load up a DVD in V2M - do you get a FFv icon in the system tray on the bottom right of your screen/taskbar?
    No, I don't see a FFv icon in the system tray. Hopefully this suggests a solution.
    Thanks.
  6. Member ChrissyBoy's Avatar
    Is your "merit" now at the max? Can you try a reboot thereafter?
    I'm also trying the DirectX Diagnostic Tool (DXDiag) to see if anything may suggest what the problem is.
    Thanks for your help. I'll be back online in about an hour.
    DirectX Diagnostic Tool didn't suggest any problems.
    With DirectShow control Merit: still set on 'very high' I've rebooted and still get the same error when I attempt to preview the video.
    To help, I've also tested DVD Shrink which has a preview which works using "Built-in Software Renderer" but not when using "System Default Renderer"
    Hope you can suggest some ideas?
  1. dvd-lab pro preview window doesnt play any sound
    By samifox in forum Authoring (DVD)
    Last Post: 28th Nov 2006, 09:11
  2. Background clip longer than preview clips?! dvd lab pro
    By jjpro11 in forum Authoring (DVD)
    Last Post: 5th Nov 2006, 02:43
  3. Subtitle preview in DVD-Lab Pro
    By Demonfreak in forum Newbie / General discussions
    Last Post: 19th Sep 2006, 10:27
  4. Replies: 9
    Last Post: 27th Apr 2005, 11:40
  5. DVD-Lab Pro - How to preview subtitles?
    By Colmino in forum Newbie / General discussions
    Last Post: 9th Jun 2004, 11:49
About   Advertise   Forum   RSS Feeds   Statistics   Tools
