Hi
I need to play an mkv file (6.5GB) and subtitle file on my blu ray player via an external hdd.I have to make sure the mkv file is no larger than 4GB, so my first question is how best to split the mkv file in 2?My second question is how to then get the separate single subtitle file to associate with the 2 new mkv files?Do I have to split the subtitle file also, and if so, how to do this in the right place so that they match the video of the 2 mkv files exactly?
Could I access the 6.5GB file and subtitle file from a usb stick instead?
Julie
Please use the general forum if you don't know where to post. This is not any blu-ray backuping. MKV files are not blu-ray files.
Split using mkvtoolnix. Split the subtitle file using for example subtitle workshop. I guess you have to check the sync manually against the mkv cutting.
Best Blu Ray Player to play 3D MKV (DTS audio) files off my USB HDD?
By Freaz in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Apr 2012, 22:15 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Software to split 10GB Blu-Ray File for the PS3
By Euroconvert in forum Video ConversionReplies: 7Last Post: 2nd Jan 2011, 15:48 -
help: when a blu ray movies is split into more than one m2ts file
By lodwales in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 09:51
Statistics
Newest guides
Latest tool updates
New media comments
