VideoHelp.com Forum
    Hi all,
    I have a few times succeeded in converting AVI movie files into DVDs and VCDs using Super during my time with Windows. Most of the time the volume is very low. My usual TV watching volume is circa 10-15. But when I watched the DVDs and VCDs, I need to push it to 30-40. Even that, sometimes the diction is not too clear.
    Now I'm with Mac and I'm still trying to encode my first movie. I have not succeeded yet. While I'm still at the learning curve, I would like to ask, is it possible to make the volume louder while encoding it using ffmpegX?
    I have looked into the Audio section. There are a couple of topic that is almost the same to my question but they involve other softwares.
    You may benefit from looking at the ffmpegx documentation regarding audio: http://www.ffmpegx.com/audio.html
    You see that there are several options, depending on what you want to do, and on which encoding engine you choose. For example, you can simply increase the amplitude arbitrarily (but if done blindly, you run the risk of going too far), or use the normalization function.
    Thank you for the reply. I'll look into it
  1. ffmpegX Convert but no sound
    By Ma_Long in forum ffmpegX general discussion
    Last Post: 7th Jan 2012, 07:42
  2. Remove sound that is at a louder level?
    By gutterboy in forum Audio
    Last Post: 27th Jun 2011, 10:22
  3. How to disable End of Conversion sound on ffmpegX
    By BS0D in forum ffmpegX general discussion
    Last Post: 16th Nov 2008, 19:46
  4. ffmpegX 0.0.9 - no sound in the output of a transcode
    By mattr in forum ffmpegX general discussion
    Last Post: 21st Sep 2008, 02:56
  5. ffmpegx, avi loses sound...
    By tomyknoker in forum ffmpegX general discussion
    Last Post: 17th Sep 2008, 13:29
