Does this camera capture video in DV Type 1 or 2? Based on the specs, I am guessing Type 2. Correct me if I'm wrong.
Taken from the manual:
Audio Recording system:
PCM digital sound: 16 bit (48 kHz/2 ch); 12 bit (32 kHz/4 ch)
Thread: Canon ZR200
Camcorders don't record type 1 or type 2. They record a raw DV stream that includes both audio and video. It's the capture software that determines whether the resulting AVI file is type 1 (DV audio and video in a single stream, marked as video) or type 2 (an second copy of the audio marked as an audio stream).
I plan on using VirtualDub, and if I recall the documentation section, it only works in Type 2?
VirtualDub can work with type 1 but it can't access the audio in those files. It uses Windows' VFW library which requires audio be in a separate stream. Hence the type 2 DV AVI.
Canon WP-V1
By mviverette in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 7th Aug 2009, 00:37 -
Canon XH-A1 or Canon XH-A1S?
By ProducerHarley in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2009, 23:34 -
Trouble exporting to Canon ZR200 via firewire
By Grundlebug in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 15th Jan 2007, 22:50 -
Canon ZR 45 HELP!!!
By chimaera15 in forum CapturingReplies: 1Last Post: 7th Jan 2004, 23:30
Statistics
Newest guides
Latest tool updates
New media comments
