VideoHelp.com Forum
    I recorded A LOT of video using CamStudio version 2. It will play back in windows media player perfectly and VLC. The problem is when I try to open it up in Quicktime 7.6.4 (the most recent version), all I have is a black screen. It will play for the duration of the video clip but there is no video. I didn't record audio because I am doing voice overs, so please don't worry about that.
    I just need to be able to open it in Quicktime so that I can save it as a .mov and edit in Final Cut Pro. For some reason, that won't play .avi files either.
    Qiucktime told me that I may need to install some components but didn't say which ones, so I installed Divx and Xvid from their Quicktime component page thinking those were the 2 most common to fix most problems dealing with codecs.
    Does anyone have a solution to this problem? I really need to be able to convert this video soon. Work depends on it.
  2. Member terryj's Avatar
    Install Perian.
    Try to open one of the files in VLC, and
    Show the Video Info ( cmd I) on the file.
    select codec details.
    Stream 1 should be your video codec used, toggle the arrow beside
    Stream 1 to determine what codec you need.
    Repeat for Stream 2 which should be your audio ( Stream 0 is sometimes
    audio as well)
    post back that info, and we can help further.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  1. How to import MTS files in Final Cut Pro 6?
    By Benhermies in forum Mac
    Last Post: 17th Feb 2012, 00:22
  2. Replies: 3
    Last Post: 24th Aug 2011, 11:40
  3. Replies: 3
    Last Post: 18th Aug 2011, 16:21
  4. Replies: 12
    Last Post: 14th Dec 2010, 16:59
  5. How to import MTS files in Final Cut Pro 6?
    Last Post: 11th Sep 2009, 02:32
