I recorded A LOT of video using CamStudio version 2. It will play back in windows media player perfectly and VLC. The problem is when I try to open it up in Quicktime 7.6.4 (the most recent version), all I have is a black screen. It will play for the duration of the video clip but there is no video. I didn't record audio because I am doing voice overs, so please don't worry about that.
I just need to be able to open it in Quicktime so that I can save it as a .mov and edit in Final Cut Pro. For some reason, that won't play .avi files either.
Qiucktime told me that I may need to install some components but didn't say which ones, so I installed Divx and Xvid from their Quicktime component page thinking those were the 2 most common to fix most problems dealing with codecs.
Does anyone have a solution to this problem? I really need to be able to convert this video soon. Work depends on it.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
What codec did you use for capture?
You might be able to use ffmpeg to re-wrap in .mov, or encode to h.264 in .mov, or even convert to uncompressed .mov if you didn't want to lose quality.
I guess it was the default codec in CamStudio (CamStudio Lossles Codec v1.4)
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 16:55 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 15:33 -
Video files recorded on my camera won't play
By sskkdeckman in forum Newbie / General discussionsReplies: 15Last Post: 30th Nov 2009, 18:02 -
Recorded DVD won't play in my laptop
By vpanganiban in forum Software PlayingReplies: 7Last Post: 12th Dec 2008, 02:53 -
I Can't Play Back Recorded Shows
By ttibsen in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2007, 09:54
Statistics
Newest guides
Latest tool updates
New media comments
