As a newbie to this software, I'm clearly missing something in simply converting an .avi file to DVD format, so I can put it on a disk.
I'm using the "HOW TO MAKE A DVD..." guide.
I choose AVI for input and DVD ffmeg for output. I don't change the in/out filenames at the top.
After the encoding is done, the guide tells me that there's supposed to be a "movie.DVD" folder with AUDIO_TS and VIDEO_TS files inside. NOT on my computer there isn't. The only file created has my original file name plus a ".ts" extension. I can't do anything with that without getting some sort of invalid format message from Toast or Popcorn or the built-in Apple software.
Where am I going wrong?
Thread: AVI to DVD
Have you checked the "Author as" box in the Options tab and get the drop down menu to be as DVD(VIDEO_TS)?
If you want to create a DVD, do not use the MPEG-TS preset, but use one of the DVD presets instead.Originally Posted by cpwhaley
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
Statistics
Newest guides
Latest tool updates
New media comments
