VideoHelp.com Forum
    Model No: DVP5992/37
    Tray stuck. Not opening when Eject button pressed. Makes a cracking sound.
    Partha
    I have a DVD Player. Model DVP5992/37
    Tray not opening when Eject Button is pressed.
    Makes a crackling sound byr tray won't open,
    Can any body offer a solution?
    Partha
    Unplug device.
    Philips head screwdriver; remove cover.
    Investigate.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    pops49, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
    Have you unplugged it for a few minutes, then holding down the eject button, plug it in? But the 'cracking' sound may be from a stripped drive gear. If it's under warranty, I would replace it. If you can't get your disc out, you will have to do what filmboss80 suggests as I don't think those players have a manual eject hole. But be gentle. Those players break easily.
    And welcome to our forums.
    EDIT: And pops49, you generally just put something else in your signature, not part of the post. That would appear in every post you make from now on. Look at some other's members signatures or you don't need to use one if you want.
  1. New Philips DVP5992 DVD player with USB 2.0 feature!!
    By agidol in forum DVD & Blu-ray Players
    Last Post: 30th Jul 2011, 10:25
  2. Philips DVP5992 Picture Discoloration
    By i am a hobo in forum DVD & Blu-ray Players
    Last Post: 18th Mar 2011, 21:01
  3. DVP5992 Philips sound issue
    By udidwht in forum DVD & Blu-ray Players
    Last Post: 21st Nov 2010, 21:58
  4. Help with Philips DVD Player DVP5992
    By bigmarky in forum DVD & Blu-ray Players
    Last Post: 13th Nov 2009, 13:00
  5. DVD tray won't eject...
    By zowiemagic in forum DVD & Blu-ray Recorders
    Last Post: 25th Dec 2007, 15:03
