During a firmware instalation my DVD went off, now it displays "00000", is there a way to do a factory reset or a way to fix this problem
While the machine is powered on you want to hold down both the CH up and CH down (on the main unit) for at least 5 seconds.
This will do a factory reset, but if you're firmware is corrupted I'm not sure if it's going to help you.
Note I've read you want to burn firmware updates to CDs and not DVDs, not sure if this could have caused your problems?
thanks...alerady done it and did not work, by the way the firmware as burned into a CD...
Any other suggestion/advice on how to fix it will be apppreciated...
If you can find an older version of the firmware you can try to load that, but if you lost power during a firmware upgrade, sometimes the player is destroyed. That is one of the risks that can happen during firmware upgrades - if the upgrade is interrupted, the upgrade will be corrupted and it can make the player useless. You could try to get the player repaired and get new firmware in it, but that will probably cost as much as a new player.
thanks, any idea of where to find and older version of the firmware
PANASONIC DMR EH55 EU firmware
By meringone in forum DVD RecordersReplies: 4Last Post: 15th May 2007, 11:11 -
Panasonic DMR-E50 Firmware Update
By emphaze in forum DVD RecordersReplies: 3Last Post: 1st Mar 2007, 13:01 -
Panasonic DMR-HS2 firmware upgrade doesn't work
By ye82 in forum DVD RecordersReplies: 1Last Post: 16th Feb 2006, 21:19 -
Panasonic DMR-E55 Firmware
By lennyt in forum DVD RecordersReplies: 0Last Post: 3rd Dec 2005, 13:00 -
Panasonic DMR-E30 Problems - Help!
By Evil Ash in forum DVD RecordersReplies: 6Last Post: 17th Mar 2005, 12:33
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
