VideoHelp.com Forum
Closed Thread
    Staff I am new here in fórum and necessary very of the aid of gurus of this community.
    Following: I download a AVI with 3 Mock-ups of Terminator 2 (Teminator of Future 2, one rip of HDDVD) with audio in English; also I download a AVI of the Terminator of the future 2 with audio dual (English/Portuguese).
    It happens that the AVI of 3 Mock-ups this with framerate of 23.976 and the Audio Dual of 29.970. I have made very this in house, being here that I do not consider "nobie" in the subject but I am being almost wild, because I do not obtain to sincronizer the audio one of the AVI of 29.970 with the AVI of 23.976.
    I'm using the Nandub to make this (because of the one to hear audio the inserted one immediately, the VirtualDubMod I did not obtain).
    Already I tried of everything, to pass AC3 WAV and to use Stretch in the SoundForge10, to pass the AC3 for 23.976 in the Belight and the AC3Machine (the voice was distorted here, that retardation that the voice leaves thickest).
    I do not know which the logic I must use to obtain this feat, please necessary very of this aid to be able to make right the Video that is a beauty with the audio one in Portuguese (my mother does not tan to read legend), I know that it must have a form to make this.
    Here the data of the archives go (in the reality they are 3, an audio dual with audio Portuguese in AC3, another audio dual with audio Portuguese in 3 MP3 and of Mock-up with audio only in English).
    Geral
    Nome completo : C:\APE FLAC WV & AVI\AVI\Freeze AVI's\O Exterminador do Futuro 2 - Dual Audio(www.TheEvolution.org by klain).avi
    Formato : AVI
    Formato/Informações : Audio Video Interleave
    Tamanho do arquivo : 705 MiB
    Duração : 2h 10mn
    Taxa de Bits Total : 752 Kbps
    Programa usado : VirtualDubMod 1.5.4.1 (build 2117/release)
    Biblioteca : VirtualDubMod build 2117/release
    Vídeo
    Formato : MPEG-4 Visual
    Perfil do Formato : Streaming Video@L1
    Conf do Formato, BVOP : Sim
    Conf do Formato, QPel : Não
    Conf do Formato, GMC : 0 warppoint
    Conf do Formato, Matriz : Padrão
    ID do Codec : XVID
    ID do Codec/Dica : XviD
    Duração : 2h 10mn
    Taxa de bits : 479 Kbps
    Largura : 512 pixel(s)
    Altura : 192 pixel(s)
    Proporção da imagem : 2.667
    Taxa de quadros : 29,970 fps
    Resolução : 24 bits
    Colorimetria : 4:2:0
    Tipo de Scan : Progressivo
    Bits/(Pixels*Quadros) : 0.163
    Tamanho da Faixa : 449 MiB (64%)
    Biblioteca : XviD 1.0.1 (UTC 2004-06-05)
    Áudio #1
    Formato : MPEG Audio
    Versão do Formato : Version 1
    Perfil do Formato : Layer 3
    ID do Codec : 55
    ID do Codec/Dica : MP3
    Duração : 2h 10mn
    Modo da taxa de bits : Constante
    Taxa de bits : 128 Kbps
    Taxa de bits mínima : 128 Kbps
    Nº de canais : 2 canal/canais
    Taxa de amostragem : 48,0 KHz
    Resolução : 16 bits
    Tamanho da Faixa : 120 MiB (17%)
    Interleave_Duration/String : 33 ms (1.00 video frames)
    Interleave_Preload/String : 504 ms
    Biblioteca : LAME3.95
    Config. da codificação : CBR
    Áudio #2
    ID do Codec : 55
    Duração : 2h 10mn
    Resolução : 16 bits
    Geral
    Nome completo : C:\APE FLAC WV & AVI\AVI\Freeze AVI's\O.Exterminador.do.Futuro.2.DVD-RIP.Dual.Audio.[FilmesDownBR].avi
    Formato : AVI
    Tamanho do arquivo : 899 MiB
    Duração : 2h 10mn
    Taxa de Bits Total : 960 Kbps
    Programa usado : VirtualDubMod 1.5.4.1 (build 2178/release)
    Biblioteca : VirtualDubMod build 2178/release
    Vídeo
    Conf do Formato, Matriz : Personalizada
    ID do Codec : XVID
    Duração : 2h 10mn
    Taxa de bits : 635 Kbps
    Largura : 576 pixel(s)
    Altura : 224 pixel(s)
    Proporção da imagem : 2.571
    Resolução : 24 bits
    Bits/(Pixels*Quadros) : 0.164
    Tamanho da Faixa : 595 MiB (66%)
    Biblioteca : XviD 1.2.0.dev47 (UTC 2006-11-01)
    Áudio #1
    Formato : AC-3
    Formato/Informações : Audio Coding 3
    ID do Codec : 2000
    Duração : 2h 10mn
    Taxa de bits : 192 Kbps
    Posições dos canais : L R
    Tamanho da Faixa : 180 MiB (20%)
    Interleave_Duration/String : 96 ms (2.88 video frames)
    Interleave_Preload/String : 96 ms
    Idioma : Portugues
    Áudio #2
    ID do Codec : 55
    Duração : 2h 10mn
    Modo da taxa de bits : Variável
    Taxa de bits : 117 Kbps
    Resolução : 16 bits
    Tamanho da Faixa : 109 MiB (12%)
    Interleave_Duration/String : 24 ms (0.72 video frames)
    Interleave_Preload/String : 511 ms
    Biblioteca : LAME3.97
    Config. da codificação : ABR
    Idioma : Portugues
    Geral
    Nome completo : C:\APE FLAC WV & AVI\AVI\Edit\Terminator.2.Judgement.Day.DirCut.199 1.HDRip.XviD.AC3-SANTi.avi
    Formato : AVI
    Perfil do Formato : OpenDML
    Tamanho do arquivo : 2,87 GiB
    Duração : 2h 33mn
    Taxa de Bits Total : 2 680 Kbps
    Programa usado : VirtualDubMod 1.5.10.2 (build 2540/release)
    Biblioteca : VirtualDubMod build 2540/release
    Vídeo
    ID do Codec : XVID
    Duração : 2h 33mn
    Taxa de bits : 2 222 Kbps
    Largura : 720 pixel(s)
    Altura : 304 pixel(s)
    Proporção da imagem : 2.35
    Taxa de quadros : 23,976 fps
    Resolução : 24 bits
    Bits/(Pixels*Quadros) : 0.423
    Tamanho da Faixa : 2,38 GiB (83%)
    Biblioteca : XviD 1.2.1 (UTC 2008-12-04)
    Áudio
    Formato : AC-3
    ID do Codec : 2000
    Duração : 2h 33mn
    Taxa de bits : 448 Kbps
    Nº de canais : 6 canal/canais
    Posições dos canais : Front: L C R, Surround: L R, LFE
    Tamanho da Faixa : 491 MiB (17%)
    Interleave_Duration/String : 42 ms (1.00 video frames)
    Interleave_Preload/String : 500 ms
    I thank the aid of yours anticipatedly., Druid®
    Buy/rent the movies and you wont have any problems.
  1. Sync 29.970 FPS audio to 23.976 FPS video?
    By LCO1971 in forum Newbie / General discussions
    Last Post: 13th Sep 2008, 15:23
  2. Difference between 23.976 fps and 23.98 fps ???
    By wasimismail in forum Authoring (VCD/SVCD)
    Last Post: 27th May 2008, 00:42
  3. Converting 23.976 fps to 29.97 fps
    By wasimismail in forum Video Conversion
    Last Post: 14th May 2008, 18:26
  4. Converting 23.976 fps to 29.9 fps
    By zanos in forum Video Conversion
    Last Post: 13th Apr 2008, 09:03
  5. 20 fps to 23.976 fps Questions
    By Maikeru-sama in forum Video Conversion
    Last Post: 27th Aug 2007, 09:16
